i think the app should block ads
DNS service is not running
s7pocxeksp
s7pocxeksp
Your debug log shows clients and domains being blocked, how have you determined that DNS is not running?
In de admin portal its showing: DNS service not running
And when i enable it stops immediately
What is the output from:
sudo systemctl status dnsmasq
● dnsmasq.service - dnsmasq - A lightweight DHCP and caching DNS server
Loaded: loaded (/lib/systemd/system/dnsmasq.service; enabled; vendor preset:
Active: active (running) since Thu 2017-07-20 20:23:36 CEST; 1 day 13h ago
Process: 4481 ExecStop=/etc/init.d/dnsmasq systemd-stop-resolvconf (code=exite
Process: 4521 ExecStartPost=/etc/init.d/dnsmasq systemd-start-resolvconf (code
Process: 4514 ExecStart=/etc/init.d/dnsmasq systemd-exec (code=exited, status=
Process: 4512 ExecStartPre=/usr/sbin/dnsmasq --test (code=exited, status=0/SUC
Main PID: 4520 (dnsmasq)
Tasks: 1 (limit: 4915)
CGroup: /system.slice/dnsmasq.service
└─4520 /usr/sbin/dnsmasq -x /run/dnsmasq/dnsmasq.pid -u dnsmasq -r /r
jul 20 20:23:34 pihole systemd[1]: Starting dnsmasq - A lightweight DHCP and cac
jul 20 20:23:34 pihole dnsmasq[4512]: dnsmasq: syntax check OK.
jul 20 20:23:36 pihole systemd[1]: Started dnsmasq - A lightweight DHCP and cach
I had the same issue when installing pi-hole on a new Debian 9 install
got the message "DNS server not running"
i found out that the dns server was running.
The netstat command wasn't known by default.
so i've installed net-tools and now it shows dns server is running.
maybe this can be your problem?
apt-get install net-tools
Socio,
Thank you so much! This was exactly my problem!
This helped me too as I had the same problem. Running pihole on pi3 with debian stretch 64bit (not raspbian).
2 posts were split to a new topic: DNS service not running after 3.3 update
