DNS service not running after 3.3 update
Hi Dan
admin portal its showing: DNS service not running
While in my case: net-tools is already the newest version.
sudo systemctl status dnsmasq gets:
● dnsmasq.service - dnsmasq - A lightweight DHCP and caching DNS server
Loaded: loaded (/lib/systemd/system/dnsmasq.service; enabled)
Drop-In: /run/systemd/generator/dnsmasq.service.d
└─50-dnsmasq-$named.conf, 50-insserv.conf-$named.conf
Active: failed (Result: exit-code) since Mon 2018-02-19 17:09:29 UTC; 47s ago
Process: 1969 ExecStartPre=/usr/sbin/dnsmasq --test (code=exited, status=1/FAILURE)
This happend while i upgraded from: Pi-hole Version v3.2.1 Web Interface Version v3.2.1 FTL Version vDev (master , v2.13.1)
to:Pi-hole Version v3.3 Web Interface Version v3.3 FTL Version v3.0
any suggestions?
best regards
Santo
I've the same issues as lastphoenix this was right after upgrading to:Pi-hole Version v3.3 Web Interface Version v3.3 FTL Version v3.0
Check the updates at the top of the blog post:
thx. i did not see this post before. Now i got it (to work).
Hi Mcat12
Well now pi-hole is runing and is blocking as i would ecptect it. thx for your documentation on how to get the lastest dnmasq.
But After one day in use, my "loca forward destination" droped from 52% to 36%. Also some ping test are indicating that caching is no longer working. Do you have observed this issue yet?
greetings
lastphoenix
We haven't seen this come up, but it is most likely just a variance in how the network is using Pi-hole that day, or since dnsmasq was restarted the cache had to be rebuilt and so more requests were forwarded.
