Hi ,
more website is slow for example :
I'm not use ipv6 on my network and i'm use pihole under Virtual Computer jessie 8
my debug token is _1mp4mqm34h_
Has you got one idea for this problem.
thank's for your help.
Hi ,
Have you followed the steps here:
I make It and upgrade y Debian 8 to 9 but it's not change shown web site.
i remake.
and my token is ikx3kywpi3
thank's for you help
What is the output of dnsmasq -v?
I don't really see anything wrong in the debug log.
hi
dnsmasq -v
i obtain this
root@srv-PiHole:~# dnsmasq -v
Version de Dnsmasq 2.76 Copyright (c) 2000-2016 Simon Kelley
Options Ă la compilation IPv6 GNU-getopt DBus i18n IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth DNSSEC loop-detect inotify
Ce logiciel est fourni sans AUCUNE GARANTIE.
Dnsmasq est un logiciel libre, il vous est permis de le redistribuer
sous les termes de la licence GPL (GNU General Public License), version 2 ou 3.
The dnsmasq version is good. Did you follow the link @jacob.salmela posted?
Yes I'm read and make this opération explain in this link and no obtain good result.
Open the browser dev tools (F12) and use the network tab to see what is causing the query to take so long.
look this test
you see more script not respond
for facebook;
What is the output of sudo iptables -L
here is the result of the order
root@srv-PiHole:~# iptables -L
Chain INPUT (policy ACCEPT)
target prot opt source destination
REJECT tcp -- anywhere anywhere tcp dpt:https reject-with tcp-reset
REJECT udp -- anywhere anywhere udp dpt:80 reject-with icmp-port-unreachable
REJECT udp -- anywhere anywhere udp dpt:443 reject-with icmp-port-unreachable
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
Did you try adding the iptables6 rules as well (even if they IPv6 isn't enabled)? Run pihole -d for a new debug token.
ok look the new debug token 2ziyvzg4ov
and see my
/etc/iptables/rules.v6
root@srv-PiHole:~# cat /etc/iptables/rules.v6
# Generated by ip6tables-save v1.6.0 on Wed Feb 28 09:35:40 2018
*filter
:INPUT ACCEPT [0:0]
:FORWARD ACCEPT [0:0]
:OUTPUT ACCEPT [0:0]
-A INPUT -p tcp -m tcp --dport 443 -j REJECT --reject-with tcp-reset
-A INPUT -p udp -m udp --dport 80 -j REJECT --reject-with icmp6-port-unreachable
-A INPUT -p udp -m udp --dport 443 -j REJECT --reject-with icmp6-port-unreachable
COMMIT
# Completed on Wed Feb 28 09:35:40 2018
Run pihole -d for a new debug token. I was on vacation for awhile, and the rest of the team has also been busy working on getting the next update out the door.
it does not matter, thank you for seeing my problem.
my new token ob4j66201f
Your IPv6 address doesn't match what's in gravity.list. Have you looked at:
Ii put the IPv6 see on the pinhole -d in setupVars.conf
but not change this situation.
Did you run pihole -r > Repair after making this change?
the problem does not change.
I think my problem comes from my wifi router.
What happens if you clear all of your iptables does the problem still exist?
