Would it be possible to have an 'Add' button in the gui settings page for dns servers so you can add as many as you like?
I find that different times of day different servers respond better - it would be good if i could list say 6 servers without using Unbound
Should be simple to implement? im sure theres a config file one could edit but be nice in the GUI for the regular user
DL6ER
November 26, 2021, 11:43am
2
You can already add as many servers as you like to. Do you mean you want more than the four custom DNS server fields?
Genisis
November 26, 2021, 3:24pm
3
"....more than the four custom DNS server fields" Would be nice upgrade. UP vote on this idea.
jfb
November 26, 2021, 4:33pm
4
In the absence of this feature, you can edit file /etc/pihole/setupVars.conf and add as many DNS servers as you like. Then restart pihole-FTL.
Follow the existing format and add additional lines as needed.
PIHOLE_DNS_1=9.9.9.11
PIHOLE_DNS_2=149.112.112.11
Please vote an already existing feature requests
There is no GUI option to set this. Shouldn't be too difficult to add.
Hello all,
Currently I have pi-hole querying 8 local stubbys that are listening on 8 separate local ports doing dns over tls. I then have the stubbys piped through 8 separate tors. I can easily accomplish adding all of the extra local nameservers(server= entries) to a separate dnsmasq.d file and it happily makes it's way and works well. But, I was thinking it would be nice to be able to have a simple "add another dns server" selection in pi-hole to be able to add as many as are desired instead …
