Lost connection to api on web ver vDev (HEAD, v3.2.1-0-g31dddd8)
api showing stats
api desktop stats loading animation in all the fields
3y6ja96h4d
Have you flushed your browser cache?
Yes i tried the control-F5, flushing chrome's cache and the service pihole-FTL restart.
BTW thank you for all your help. Love the pi-hole.
Is it all the fields or just one?
All the fields except for the 4 at the top of the page: total queries, queries blocked, percent blocked and domains on blocklist. All the rest have spinning indicators. i have pi-hole installed on jessie. i had a similar problem with the api. It seems when i rolled back my version to 3.2.1, the problem was fixed.
Its load very slow for me, but works after like 1- 2 min.
Unfortunately the fields are loading indefinitely. Not sure if I should reinstall pi-hole on raspbian stretch. Maybe jessie is the problem.
I'm still working to track down why it won't load for some people, but loads fine for others..
Make a new debug token. Also, if you want to use the development version, make sure you're on the latest version.
I reinstalled a backup of raspbian jessie with pihole several days ago since the raspberry pi stopped working.
I updated to the newest version:
Pi-hole Version v3.3.1 Web Interface Version v3.3 FTL Version v3.0.
Pihole seems to work but still unable to see logs. i have graphs but they are old and do not update.
debug token is: jef4jyqs3h
Sorry, make a new debug token. You probably are running into this issue:
