LInksys Router Won't Designate Pi-hole as DNS
Using Pi-hole on Umbrel v 0.4.17 ( https://getumbrel.com/ )
After designating the DHCP server settings on my linksys router to point to Pi-hole on local network as DNS, Linksys router should designate the Pi-hole as the default dns server for all local clients.
I followed option 1 instructions here : How do I configure my devices to use Pi-hole as their DNS server?
After setting is applied, router reports no internet connectivity.
My Pi-hole has a reserved address from DHCP.
I am not using conditional forwarding, as recommended by Setting Google Wifi DNS to pihole breaks internet connection.
The Pi-hole team doesn't develop Apps for Umbrel, and Umbrel isn't on Pi-hole's list of supported OSs.
So far, we've only received reports for failing installs on Umbrel, see e.g. Pi-Hole in the Getumbrel node does not install, it always stays on.
Did your installation succeed?
If you can provide us with a debug token, I'll take a look and see if I can spot something.
To that end, please upload a debug log and post just the token URL that is generated after the log is uploaded by running the following command from the Pi-hole host terminal:
Tools > Generate Debug Log
