Pi-Hole to be able to resolve Known clients name
Pi-Hole not able to resolve Known clients name
I've configured Conditional Forwarding in Pi-Hole IP 192.168.0.8.
Mikrotik IP 192.168.0.1 and the local domain name ("lan").
i have found this script:
# When "1" all DNS entries with IP address of DHCP lease are removed
:local dnsRemoveAllByIp "1"
# When "1" all DNS entries with hostname of DHCP lease are removed
:local dnsRemoveAllByName "1"
# When "1" addition and removal of DNS entries is always done also for non-FQDN hostname
:local dnsAlwaysNonfqdn "1"
# DNS domain to add after DHCP client hostname
:local dnsDomain "lan"
# DNS TTL to set for DNS entries
:local dnsTtl "00:15:00"
# Source of DHCP client hostname, can be "lease-hostname" or any other lease attribute, like "host-name" or "comment"
:local leaseClientHostnameSource "comment"
:local leaseComment "dhcp-lease-script_$leaseServerName_$leaseClientHostnameSource"
:if ($leaseClientHostnameSource = "lease-hostname") do={
:set leaseClientHostname $"lease-hostname"
} else={
:set leaseClientHostname ([:pick \
[/ip dhcp-server lease print as-value where server="$leaseServerName" address="$leaseActIP" mac-address="$leaseActMAC"] \
0]->"$leaseClientHostnameSource")
:local leaseClientHostnames "$leaseClientHostname"
:if ([:len [$dnsDomain]] > 0) do={
:if ($dnsAlwaysNonfqdn = "1") do={
:set leaseClientHostnames "$leaseClientHostname.$dnsDomain,$leaseClientHostname"
} else={
:set leaseClientHostnames "$leaseClientHostname.$dnsDomain"
:if ($dnsRemoveAllByIp = "1") do={
/ip dns static remove [/ip dns static find comment="$leaseComment" and address="$leaseActIP"]
:foreach h in=[:toarray value="$leaseClientHostnames"] do={
:if ($dnsRemoveAllByName = "1") do={
/ip dns static remove [/ip dns static find comment="$leaseComment" and name="$h"]
/ip dns static remove [/ip dns static find comment="$leaseComment" and address="$leaseActIP" and name="$h"]
:if ($leaseBound = "1") do={
:delay 1
/ip dns static add comment="$leaseComment" address="$leaseActIP" name="$h" ttl="$dnsTtl"
in this topic:
But it doesn't work for me...
Any help?
Debug Token
pihole.txt (112.8 KB)
