It doesn't block ads
Block ads
Doesn't block ads
5zxps6o4cw
Maybe one of the following FAQs helps?
Your debug log shows several problems
There does not appear to be an IP address assigned to the Pi and no clients are able to connect to this address for DNS.
[✗] No IPv4 address(es) found on the eth0 interface.
[✗] No IPv6 address(es) found on the eth0 interface.
   * Pinging 192.168.1.1...
You have Pi-Hole configured to listen on this address, but that does not appear to be the IP address of the Pi:
PIHOLE_INTERFACE=eth0
IPV4_ADDRESS=192.168.1.7/24
