Issues with PiHole (dnsmasq) DHCP - no leases left
to be able to configure necessary dhcp settings/range/options and it work accordingly
i have ample space in my dhcp range, but find that not all clients are able to receive dhcp information (ip address). in the pihole.log, i'll see this "no leases left", even though the range is not exhausted at all, only a fraction is used, yet it complains there is no space. i've even tried increasing the range to a /25 and even /24, and still it complains. not sure what is going on.
Your debug token is: https://tricorder.pi-hole.net/8j11t0t323
thank you kindly in advance,
Jamar
my apologies, updated the above with it.
thanks,
Jamar
So after some more googling and double-checking my settings, I commented out this setting "dhcp-lease-max=12", which has fixed my lease issue. The default is "1000". Guessing it was late and perhaps I thought it meant the max lease time rather than it actually meaning the max number of leases dhcp will dish out. doh :frowning:
Will update should I still have issues, thanks.
Jamar
