I'm having an issue with installing Pi-Hole after I flashed Raspbian Buster on my Raspberry Pi.
It seems like there is an issue with "Systemd-resolved".
Installation log
pi@pi:~ $ curl -sSL https://install.pi-hole.net | bash
stty: 'standard input': Inappropriate ioctl for device
[β] Root user check
[i] Script called with non-root privileges
The Pi-hole requires elevated privileges to install and run
Please check the installer for any concerns regarding this requirement
Make sure to download this script from a trusted source
[β] Sudo utility check
[β] Root user check
.ccccc:,.
:cccclll:. ..,,
:ccccclll. ;ooodc
'ccll:;ll .oooodc
.;cll.;;looo:.
[i] Existing PHP installation detected : PHP version 7.3.4-2
[β] Disk space check
[β] Update local cache of available packages
[β] Checking apt-get for upgraded packages... up to date!
[β] Checking for apt-utils
[β] Checking for dialog
[β] Checking for debconf
[β] Checking for dhcpcd5
[β] Checking for git
[β] Checking for iproute2
[β] Checking for whiptail
[i] Using Google (ECS)
[i] Static IP already configured
[i] Unable to find IPv6 ULA/GUA address, IPv6 adblocking will not be enabled
[i] IPv4 address: 10.0.0.2/24
[i] IPv6 address:
[i] Web Interface On
[i] Web Server On
[i] Logging On.
[β] Check for existing repository in /etc/.pihole
[β] Clone https://github.com/pi-hole/pi-hole.git into /etc/.pihole
[β] Check for existing repository in /var/www/html/admin
[β] Clone https://github.com/pi-hole/AdminLTE.git into /var/www/html/admin
[i] Main Dependency checks...
[β] Checking for cron
[β] Checking for curl
[β] Checking for dnsutils
[β] Checking for iputils-ping
[β] Checking for lsof
[β] Checking for netcat
[β] Checking for psmisc
[β] Checking for sudo
[β] Checking for unzip
[β] Checking for wget
[β] Checking for idn2
[β] Checking for sqlite3
[β] Checking for libcap2-bin
[β] Checking for dns-root-data
[β] Checking for resolvconf
[β] Checking for lighttpd
[β] Checking for php7.3-common
[β] Checking for php7.3-cgi
[β] Checking for php7.3-sqlite3
[β] Enabling lighttpd service to start on reboot...
[i] FTL Checks...
[β] Detected ARM-hf architecture (armv7+)
[i] Latest FTL Binary already installed (v4.3.1). Confirming Checksum...
[i] Checksum correct. No need to download!
[β] Checking for user 'pihole'
[β] Installing scripts from /etc/.pihole
[β] Copying 01-pihole.conf to /etc/dnsmasq.d/01-pihole.conf
[i] Installing blocking page...
[β] Creating directory for blocking page, and copying files
[β] Backing up index.lighttpd.html
[β] Installing sudoer file
[β] Installing latest Cron script
[β] Installing latest logrotate script
[i] Backing up /etc/dnsmasq.conf to /etc/dnsmasq.conf.old
[i] Skipping firewall configuration
[β] man pages installed and database updated
[i] Testing if systemd-resolved is enabled
[i] Systemd-resolved is not enabled
[i] Restarting lighttpd service...pi@pi:~ $
I appreciate any help. Thanks.
