The issue I am facing:
I am experimenting with running Pi-hole v6 on an Android TV box using Termux with an Ubuntu PRoot environment.
Pi-hole installs successfully and FTL starts, but FTL cannot bind to the normal DNS port 53:
dnsmasq: failed to create listening socket for port 53: Permission denied
FTL started!
I confirmed that this is not simply another service occupying port 53 by testing a direct UDP bind from Python:
PermissionError: [Errno 13] Permission denied
If I change the Pi-hole DNS port to 5353, FTL starts and DNS works correctly.
The Pi-hole web interface has also been changed to port 8080, and that works correctly.
So my current working configuration is:
Pi-hole FTL/DNS: 5353
Pi-hole Web UI: 8080
The remaining problem is finding a way to make the Android TV box accept normal DNS requests on TCP/UDP port 53 and pass them to Pi-hole on port 5353.
Details about my system:
- Android TV box
- AArch64 / 64-bit ARM
- Termux
- Ubuntu running under PRoot
- Pi-hole v6
- FTL v6.7
- systemd is not PID 1 in this environment
During installation/reconfiguration, Pi-hole reports:
System has not been booted with systemd as init system (PID 1). Can't operate.
Failed to connect to bus: Host is down
I can start/restart FTL manually using:
/etc/init.d/pihole-FTL restart
The Android firmware also has a "root" option. After enabling it, su gives:
uid=0(root) gid=0(root) groups=0(root),1077,1079,3003,9997,20084,50084
However, even from this root shell, attempts to use iptables NAT fail.
For example:
iptables -t nat -A PREROUTING -p udp --dport 53 -j REDIRECT --to-ports 5353
returns:
iptables v1.8.13 (legacy): can't initialize iptables table `nat': Permission denied (you must be root)
Perhaps iptables or your kernel needs to be upgraded.
I therefore appear to have UID 0 but not the kernel capabilities required for binding privileged ports and/or modifying the NAT table.
I changed the DNS port to 5353:
pihole-FTL --config dns.port 5353
I changed the Pi-hole v6 web interface to port 8080:
pihole-FTL --config webserver.port "8080"
Both of these work and answers DNS.
The web interface is accessible on:
http://<Android-box-IP>:8080/admin/
and FTL successfully listens on port 5353.
I also tried using Android root/iptables to redirect normal DNS traffic:
TCP/UDP 53 -> 5353
but Android denies access to the NAT table even after su.
My main question is:
Is there a supported or practical way to allow Pi-hole FTL to use port 53 in a Termux/PRoot Android environment, or alternatively redirect TCP/UDP port 53 to FTL on port 5353 when Android provides UID 0 but apparently does not provide the necessary network capabilities?
Debug logs:
