Details about my system:
Pi-hole v5.2
Linux [device] 5.4.51-v8+ #1327 SMP PREEMPT Thu Jul 23 11:11:34 BST 2020 aarch64 GNU/Linux
The issue I am facing:
I'd like to completely uninstall cloudflared from my Raspberry Pi. (I know how to remove the config from Pi-hole.) If there are any instructions on how to do this I'd appreciate it. The only thing I've found (here) seems like a brute force delete of files / dirs and not a clean uninstall.
What I've done so far:
- I began by stopping and disabling the cloudflared services. (I think there are only two? I don't know for sure.)
sudo systemctl stop cloudflared
sudo systemctl stop cloudflared.service
sudo systemctl disable cloudflared
sudo systemctl disable cloudflared.service
- The service appears to be stopped.
$ sudo systemctl status cloudflared.service
ā cloudflared.service - cloudflared DNS over HTTPS proxy
Loaded: loaded (/etc/systemd/system/cloudflared.service; disabled; vendor preset: enabled)
Active: inactive (dead)
[... snip ...]
Aug 17 11:41:31 [device] systemd[1]: Stopping cloudflared DNS over HTTPS proxy...
Aug 17 11:41:31 [device] systemd[1]: cloudflared.service: Succeeded.
Aug 17 11:41:31 [device] systemd[1]: Stopped cloudflared DNS over HTTPS proxy.
- However, I can't seem to successfully run any type of uninstall. Here's what I've tried:
$ sudo apt-get remove cloudflared
Reading package lists... Done
Building dependency tree
E: Unable to locate package cloudflared
And for cloudflared.service ...
$ sudo apt-get remove cloudflared.service
E: Unable to locate package cloudflared.service
E: Couldn't find any package by glob 'cloudflared.service'
E: Couldn't find any package by regex 'cloudflared.service'
- I added "arm_64bit=1" to the end of /boot/config.txt
(this had no impact on Pi-hole, it ran fine after that.)
Thanks.
