Enable HTTPS on Pi-hole (pihole-https)
If you want a simple way to enable HTTPS on your Pi-hole web interface, check out this project:
β https://github.com/luizbizzio/pihole-https
If this project helps you, consider giving it a star on GitHub!
Install
curl -fsSL https://raw.githubusercontent.com/luizbizzio/pihole-https/main/pihole-https.sh | sudo bash
Uninstall / Revert
curl -fsSL https://raw.githubusercontent.com/luizbizzio/pihole-https/main/uninstall-pihole-https.sh | sudo bash
In case of questions, troubleshooting, or additional information, please check the repository.
nero355
2
Please read : Preparing for 47-Day SSL/TLS Certificates: What You Need to Know - SSL.com
And adjust your script accordingly
Also : Is the SSL Certificate going to be from Letβs Encrypt ?!
Hp3
3
Based on the repo last changed 5 days ago, the renewal date is set to 40 days with a 7 day windowβ¦. so 47 days.
nero355
4
Indeed, this topic is also outdated now : Please have a look at the new one!
