All the Pi-Hole documentation is still in draft? If I go to: https://pi-hole.net/, then click "install pi-hole" then scroll up on github so the menu bar is visible, then click "Wiki" it states: Note that the most recent documentation can he found here: https://docs.pi-hole.net, then click the link and go to: "https://docs.pi-hole.net/" (without the deploy-preview) and if I then look at FTLDNS -> Configuration, or use the search function and search for "pi.hole" I can see " PIHOLE_PTR=true option there.
So the option is there and documented, it's just hard to find. (hence my suggestion to make a link from pi-hole.net to docs.pi-hole.net and in the mentioned config files, since you now host the documentation yourself there is less change of a link not working)
I have never seen pi.hole in any configuration or DNS reply (maybe in a default configuration, but that's years ago), and it might have shown as "unknown" for some users. Until the recent change.
I'm not really sure what you mean. With mDNS, sure, it's all UDP and broadcast.
But the whole point of Pi-hole is a central, robust, caching, adblocking DNS server with a lot of great features and easy to manage. Not mDNS but real DNS, with a server that should reply with a correct forward and reverse DNS.
I have never been in a situation that I had to rely on mDNS for internal DNS resolution for at least 10 years, with Windows domaincontrollers in the past and the last years Pi-Hole since the configuration and features are WAY better.
The hostname for my Pihole was (and was always set) in "Local DNS Records" this ends up in "custom.list" and get's loaded when FTL is restarted.
DNS was set static just like the IP, however this gets overwritten by pi.hole if you DONT explicitly set the PTR_PIHOLE=false in /etc/pihole/pihole-FTL.conf
It was also possible to see the chain of configuration: /etc/dnsmasq.conf loads: /etc/dnsmasq.d/* that loads addn-hosts=/etc/pihole/local.list and addn-hosts=/etc/pihole/custom.list etc.
Until the change, my pihole always returned the correct forward and reverse DNS, so when I went looking at the configuration files, there is NO mention of pi.hole, however my pihole is suddenly replying with this new name.
So the situation is now:
/etc/hostname has no effect (I'm not really sure that's the correct behavior, but fine)
/etc/pihole/custom.list has no effect and there is no mention of a DNS record pi.hole (the correct IP and matching hostname are in there, but are ignored)
/etc/pihole/local.list has no effect and there is no mention of a DNS record pi.hole (whats the purpose for this file?)
So my point is: it should be more clear. It's your project and what you do with with it and how you implement it. But leaving out critical information (or overwriting customized settings) might lead to confusion when looking at configuration files or a webinterface.
A long time ago the pi reply'd with server: unknown/IP, not sure what happened, some config file or something I messed up, but a DNS server that does not know it's own name.... yeah. So, I add the IP and hostname in the webinterface via "Local DNS Records" verify: awesome, forward and reverse DNS works like I expect with the address and IP as configured.
But somehow this all changed after the last update and the pi has decided to change his name to pi.hole. So now:
If you want to set the DNS record of a host within the network you can set it via /etc/pihole/custom.list or in the webinterface via "Local DNS Records" EXEPT if you want a hostname for the Pihole itself, then you have to set PIHOLE_PTR=false and PIHOLE_PTR=<HOSTNAME>* in /etc/pihole/pihole-FTL.conf
*not yet implemented
Dont get me wrong, I understand the reasons behind it and I have fought with a lot of docker containers over the years to get them to work like advertised.
But if you put more settings in pihole-FTL.conf and can't rely on proper DNS resolution and configuration files of dnsmasq what can you trust?
Default: pi.hole: yes, but make it a toggle button on the webinterface 'Let FTL handle pi.hole record' so it can work like before the change. (don't overwrite custom.list)
