Is it possible to disable the pi.hole
entry without editing the /etc/pihole/local.list
manually and adding a writing protection to it?
Anyone any ideas?
Seeing as pi.hole
is defined in local.list
, there would be no way to remove it without first editing that file..
Is the existence of pi.hole
causing issues for you?
