Pi-hole was designed be to very easy to install. Simply run this command from your server:
curl -sSL https://install.pi-hole.net | bash
and follow the on-screen prompts. Then sit back while it installs everything for you.
A post was split to a new topic: Unable to install Pi-hole (curl error)
2 posts were split to a new topic: Block Page not working
