How do I clear the blacklist?
I'd like to clear the blacklist. I uploaded a tarball with three black list entries with the teleporter and selected blacklist (exact) and checked the box for clear existing data. It successfully uploaded.
When I go back to the blacklist, I still have all of the previous entries.
I rebooted my pi and ran pihole -g
How many do you have on your blacklist?
You can delete them one by one.
I have 3,000
Wipe everything and start from scratch. Consider this a learning experience.
Is there a file on the pi hole that I can delete instead?
I'm not super concerned because they're duplicated with my custom list. I figure dups can't hurt.
Hi, I had a similar problem, and asked in this thread
yubiuser was very helpfull and gave me this answer:
Which version are you using? You can easily delete multiple or all blacklist entirety via Sql on the command line in version v5.
https://docs.pi-hole.net/database/gravity/
To delete all exact blacklist
sudo sqlite3 /etc/pihole/gravity.db "delete from domainlist where type=1;"
All the adlists and domain lists are kept in a single database at /etc/pihole/gravity.db. You can manipulate entries in that database from the command line as described in this section of the documentation.
Hi jfb! Sorry for cross-posting, mind taking a look at this post?
Thank you!!
