Help setting up with Netgear router
Hey all, I'm not sure if I've set up Pihole correctly with my Netgear Nighthawk r7400 router. Since there aren't any DNS settings in the LAN settings of the router, I just unchecked "use router as DHCP" and enabled DHCP server in Pihole and filled out the addresses to hand out and the router address.
Do I need to change the DNS settings of my router as well? Currently it's set to auto from provider and on pihole, the upstream is OpenDNS.
On my netgear router I had to go to
> Advanced > Setup > Internet Setup > Domain Name Server (DNS) Address
Then delete all the DNSes already there, and replace my Primary DNS with the IP of my Pi-hole.
More on that at this link.
