Help, PIhole does not block domains provided
Fresh install of pihole.
first nothing shows in querys (nothing)
I can resolv domain names with pihole (using nslookup)
the domains I insert as blacklisted is getting resolved and the only blocks that works is that ad-list thats available when installing.
have updated, restarted pihole.
nothings works.
Are you sure your devices are using Pi-hole as DNS server?
Did you make changes to your router or devices to use Pi-hole?
Yes (manuelly configured dns in ipv4 settings)
And yes (have also tried with configure the dhcp server to use pihole dns server
I have installed it on a azure Virtual Machine
And set up a site 2 site vpn tunnel between azure cloud and my firewall.
Tools > Generate Debug Log
https://tricorder.pi-hole.net/ujIoIw3M/
Your debug log shows that Pi-hole is fully operational and does block if requested. However, it has barely received any queries
  [2023-04-19 12:38:26.778 2272M] Imported 11 queries from the long-term database
   [2023-04-19 12:38:26.778 2272M]  -> Total DNS queries: 11
   [2023-04-19 12:38:26.778 2272M]  -> Cached DNS queries: 7
   [2023-04-19 12:38:26.778 2272M]  -> Forwarded DNS queries: 0
   [2023-04-19 12:38:26.778 2272M]  -> Blocked DNS queries: 4
   [2023-04-19 12:38:26.778 2272M]  -> Unknown DNS queries: 0
   [2023-04-19 12:38:26.778 2272M]  -> Unique domains: 4
   [2023-04-19 12:38:26.778 2272M]  -> Unique clients: 4
   [2023-04-19 12:38:26.778 2272M]  -> Known forward destinations: 0
Maybe it's because Pi-hole's IP does not match the one distributed by your DHCP server.
Please post the output of those commands from a client
nslookup pi.hole
nslookup flurry.com
nslookup flurry.com @PI-HOLE_IP
Your Pi-hole is configured for the ethernet interface at this IP:
[✓] netflipld.com is 0.0.0.0 on lo (127.0.0.1)
[✓] netflipld.com is 0.0.0.0 on eth0 (**192.168.59.196**)
[✓] doubleclick.com is 142.250.74.46 via a remote, public DNS server (8.8.8.8)
Your DHCP server (which may be on a different VLAN, is offering up a different DNS server than Pi-hole.
   Timeout: 10 seconds
   * Received 372 bytes from eth0:168.63.129.16
     Offered IP address: 192.168.59.196
     Server IP address: 168.63.129.16
     Relay-agent IP address: 168.63.129.16
     BOOTP server: OSL211051213045
     BOOTP file: (empty)
     DHCP options:
      netmask: 255.255.255.240
      router: 192.168.59.193
      dns-server: 168.63.129.16
      domain-name: "01oh4d44njmubfwqt2mmpi0znc.oslx.internal.cloudapp.net"
      lease-time: Infinite
      Message type: DHCPOFFER (2)
      server-identifier: 168.63.129.16
      renewal-time: Infinite
      rebinding-time: Infinite
      Unknown option 245: A8 3F 81 10 (length 4)
         --- end of options ---
     BOOTP file: (empty)
     DHCP options:
   DHCP packets received on interface eth0: 2
   DHCP packets received on interface enP5555s1: 0
