Pi Hole to block ads.
Not working on Windows laptop, or iPhone 6s.
BUT, the local dashboard is working just fine...I can view it in my browser.
a4jxeduto3
a4jxeduto3
Have you changed the DNS Settings in your router and restarted your devices?
For full details see.
May I ask which block lists you are using?
I am currently using method two suggested above (manually setting each device as needed). I did notice last night that when I was further away from my router and using it’s slower ipv4 (blissfully ignorant as to how that works) it did end up blocking ads.
When I set the Pi up initially I only selected IPV4. I always thought that Ipv 4/6 used the same dns regardless.
Anyone can open an issue on Github. https://github.com/pi-hole/pi-hole
Interesting a distance problem. Do you run Dual Band WIFI?
I have turned my high speed off, the way it bounces around and may drop out some times.
I have dual band, stock gateway from Xfinity. I’ll try turning off dual band and see if that helps with the issue. Thanks for the speedy response!
