Group Management list groups, can add groups or change groups
Error message about DataTables and can't create groups.
https://tricorder.pi-hole.net/mlvevt5c4p
Thinks i already did
Add pihole to the group www-data
Add www-data user to the group pihole
Can't access the table group in 'sqlite3 /etc/pihole/gravity.db'
Uninstalled Pi-Hole and reinstalled
Env
Rarsp 3+
NGINX Frondend webserver
PHP 7.3
Coro
May 13, 2020, 7:30am
2
Do you use lighttpd (installed by Pi-hole) as web server? If so, are there errors in /var/log/lighttpd/error.log ?
Also note that after
you need to reboot the device.
i don't use lighttpd, but nginx.
Yes i did this after i added the group.
Coro
May 13, 2020, 9:10am
5
He already added the user www-data to group pihole. While the other one isn't necessary, it is also not harmful. He already restarted nginx by rebooting his device so this cannot be the solution here.
anon55913113:
sudo usermod -a -G pihole www-data sudo systemctl restart nginx
Still not working! many reboots and restarts later.
Nginx is running on www-data, php-fpm is running under www-data.
listen.owner = www-data
listen.group = www-data
https://192.168.178.5/admin/scripts/pi-hole/php/groups.php
has the same error message.
i configured nginx with de guide https://docs.pi-hole.net/guides/nginx-configuration/
but have also a seperated website directly to the admin page. both websites does not work.
i found it! php7.3-sqlite was not installed! Stupid me!
What is the difference between a domain name pi-hole and an ip address? If you look closely at the configuration at https://docs.pi-hole.net/guides/nginx-configuration/
http://192.168.178.5 is the same as http://pi-hole because pi-hole resolves to 192.168.178.5 and the nginx site config has the default_server tag.
And HTTPS even if it is an internal website, it just needs to be secured with an HTTPS connection. But we are not going to have this discussion here.
