To be able to assign blacklist entries to a group
-operating system - Docker
-hardware Qnap TS451+
The blacklist page keeps hiding the Group Assignment column, all it takes is a page refresh and the group assignment column disappears. Cookie clearing resolves the problem until the page is refreshed.Screenshots attached
https://tricorder.pi-hole.net/9pe82u4mdc
This is the intended behavior. If you want to see the group assignment of black/whitelist you have to go to "Group Management/Domains"
ADD
See this topic for more information
The Group Assignment column should be appearing between the Comment and Action columns on both the Whitelist page and Blacklist page.
The Group Assignment column appears once and then will never re-appear unless you clear out your browsing history.
https://tricorder.pi-hole.net/dswp0sj7mg
Further Information:
I can replicate the problem in multiple browsers (Chrome, Edge Chromium,…
Thanks for pointing out. That helps
and I apologise for a duplicate post. Missed it.
DL6ER
May 26, 2020, 9:23pm
4
Thanks for reminding me of this issue.
Bugfix prepared and pushed:
https://github.com/pi-hole/AdminLTE/pull/1393
Glad to be of assistance!
system
Closed
June 16, 2020, 9:36pm
6
