FTLDNS stops working
Pihole loses connection to FTL when using FTLDNS.
After some hours Pihole stops working and shows FTL lost. After going back to standard FTL everything works fine. Switching again to FTLDNS Pinole works for some hours and then stops again. Does someone have an idea? thanks.
This is the token generated with standard FTL: ah9h6srz14
Do you need another one with FTLDNS?
Here is another one after installing FTLDNS. o0rk3ago6p
Hope it helps. Thanks.
[2018-04-07 19:24:29.688] FATAL: FTL received SIGTERM from PID/UID 15325/0, exiting gracefully
What was running under PID 15325?
Sorry, how can I find what was running under PID 15325?
ps -p 15325 -o comm=
root@DietPi:~# ps -p 15325 -o comm=
root@DietPi:~# ps -p 15325 -O comm=
PID S TTY TIME COMMAND
Is this what you required? I had to use the capital O to see a result.
Whatever was running is probably not running anymore.
Whatever it was, it was running as root - likely it was a service pihole-FTL stop ommand :slight_smile:
