FTL Offline
FTL ist dauernt offline und ich weiß nicht wie ich es online kriegen kann. Was kann ich da machen?
My token is 8uxkk311tf
You have another DNS service running on port 53 (BIND9?) which is preventing FTL from running on that port.
Wow great that worked thank you very much! I just needed to unintall bind9 with this: sudo apt-get remove bind9
Now I have the problem that its not bloking any ads. I can still see all ads :frowning_face:
Please run another debug log and post the token.
d9mvve07hn
If you look on your admin dashboard top right red box "Domains on Blocklist", you will likely see a number near zero (or zero). Your debug log shows that your gravity list is empty.
Update gravity from either the web admin GUI > tools > update gravity or from the command line with pihole -g
Why does it says that if I try to update the config?
[✗] Update local cache of available packages
Error: Unable to update package cache. Please try "apt-get update"
What command were you running and do you still have the output of that command? If so, please post it.
I get to fix that but now when I try to make pihole -r it always get stuck on this screen:
Package configuration
┌───────────────────────────────────────────────────────────────────────────────────────────┤ Installing packages ├────────────────────────────────────────────────────────────────────────────────────────────┐
│ Preparing to configure dhcpcd5 (armhf) │
│ 15% │
