Okay, the local repositories show that they are up to day, however that debug log is the old version. It appears that the update did not copy over the contents of the local repositories over to their proper locations in the rest of the Pi-hole. Can you run a pihole -r and see if we can get the files moved to the right locations?
Bingo! U da man, Dan!
I really appreciate your help.
... Was just telling my wife ... How is it I can get real0tiemn help from one of the developers of software I consider to be very valuable. I sent u guyz only about $40 and you are unlikely to associate that contribution with me.
Now, if I have problems with Act!, Windoze, QuickBooks, etc, the support is nil or really expensive.
Something wrong with this picture. So ... I'll send you a few more $$.
There was one apt repository offline which has no relationship to pihole. The warning seems to stop the repair script. After I remove the apt-source the script runs without problems.
But I had to run reconfigure.
Formatting domains into a HOSTS file...::: No IP Values found! Please run 'pihole -r' and choose reconfigure to restore values
After reconfiguring with the stored values everything works.
