pi@raspberrypi:~ $ sudo su
root@raspberrypi:/home/pi# pihole -up
::: Checking for updates...
fatal: unable to access 'GitHub - pi-hole/pi-hole: A black hole for Internet advertisements': Failed to connect to github.com port 443: Connection refused
fatal: Upstream branch 'refs/heads/master' not stored as a remote-tracking branch
::: Error: Remote revision could not be obtained, ask Pi-hole support.
::: Additional debugging output:
On branch master
nothing to commit, working directory clean
pi@raspberrypi:~ $ pihole -up
On branch master
pi@raspberrypi:~ $
pi@DNS-SERVER:~ $ sudo su
root@DNS-SERVER:/home/pi# dpkg -s ca-certificates
Package: ca-certificates
Status: install ok installed
Priority: optional
Section: misc
Installed-Size: 367
Maintainer: Michael Shuler michael@pbandjelly.org
Architecture: all
Multi-Arch: foreign
Version: 20141019+deb8u3
Depends: openssl (>= 1.0.0), debconf (>= 0.5) | debconf-2.0
Breaks: ca-certificates-java (<< 20121112+nmu1)
Enhances: openssl
Description: Common CA certificates
root@DNS-SERVER:/home/pi# sudo apt install ca-certificates
Reading package lists... Done
Building dependency tree
Reading state information... Done ca-certificates is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Lets not do that yet though Stretch is close to stable release
@Ondrej ,
I believe your certs are fine and something else is going on causing that error "Failed to connect to github.com port 443:".
Do you still experience this error ?
Is anything displayed if doing below one ?
echo | openssl s_client -connect github.com:443
And is date/time displayed correct ?
date
And whats output for:
traceroute github.com | tail -1
*Could run last one without the "tail" bit but dont post results here!
