You ran this command exactly as written (i.e. copy / paste into the terminal)?
apparently not
also I am so sorry for the delay my internet isn't the fastest and it takes quite some time but nevertheless
root@raspberrypi:~# sudo grep -v '#\|^$' -R /etc/dnsmasq.*
/etc/dnsmasq.conf:conf-dir=/etc/dnsmasq.d
/etc/dnsmasq.conf.dpkg-old:conf-dir=/etc/dnsmasq.d
/etc/dnsmasq.conf.old:conf-dir=/etc/dnsmasq.d
/etc/dnsmasq.conf.orig:dhcp-mac=set:client_is_a_pi,B8:27:EB:*:*:*
/etc/dnsmasq.conf.orig:dhcp-reply-delay=tag:client_is_a_pi,2
/etc/dnsmasq.d/01-pihole.conf:addn-hosts=/etc/pihole/gravity.list
/etc/dnsmasq.d/01-pihole.conf:addn-hosts=/etc/pihole/black.list
/etc/dnsmasq.d/01-pihole.conf:addn-hosts=/etc/pihole/local.list
/etc/dnsmasq.d/01-pihole.conf:localise-queries
/etc/dnsmasq.d/01-pihole.conf:no-resolv
/etc/dnsmasq.d/01-pihole.conf:cache-size=10000
/etc/dnsmasq.d/01-pihole.conf:log-queries
/etc/dnsmasq.d/01-pihole.conf:log-facility=/var/log/pihole.log
/etc/dnsmasq.d/01-pihole.conf:local-ttl=2
/etc/dnsmasq.d/01-pihole.conf:log-async
/etc/dnsmasq.d/01-pihole.conf:server=8.8.8.8
/etc/dnsmasq.d/01-pihole.conf:domain-needed
/etc/dnsmasq.d/01-pihole.conf:bogus-priv
/etc/dnsmasq.d/01-pihole.conf:except-interface=nonexisting
/etc/dnsmasq.d/01-pihole.conf:server=/use-application-dns.net/
/etc/dnsmasq.d/custom-dnsmasq.conf:interface=eth0
/etc/dnsmasq.d/custom-dnsmasq.conf:bind-interfaces
/etc/dnsmasq.d/custom-dnsmasq.conf:server=8.8.8.8
/etc/dnsmasq.d/custom-dnsmasq.conf:domain-needed
/etc/dnsmasq.d/custom-dnsmasq.conf:bogus-priv
/etc/dnsmasq.d/custom-dnsmasq.conf:dhcp-range=192.168.220.50,192.168.220.150,12h
You have some files in there that are not Pi-hole files and appear to be interfering with Pi-hole. Delete or move these:
sudo rm /etc/dnsmasq.conf.orig
sudo mv /etc/dnsmasq.d/custom-dnsmasq.conf /Documents
sudo mv /var/lib/misc/dnsmasq.leases /Documents
sudo service pihole-FTL restart
you are amazing thank you
Fixed now, I assume?
That is why your post is marked the solution but lighttpd also needed a restart because that is me main dns service
or something like that
also does pi-hole network bridge
Pi-hole answers DNS queries on the network(s) to which it is attached. If you have more than one interface on the Pi-hole and select listen on all interfaces in the DNS settings, it can respond to both.
Typically, any bridging of traffic between VLANs would be done by the VLAN controller.
I can't figure out how to add my ethernet only computer to my raspi 4 with 1 eth port but a usb to eth
That is outside the scope of Pi-hole. I would check on a Raspberry Pi forum.
see though that isn't my point
my point is how are you intended to use pihole meaning how do you get other devices to use the ad blocking
