Expected Behavior:
I would just like the API and FTL to actually work
Actual Behavior:
correct me if I am wrong but I thing the FTL should be running. In my case it isn't and it also says lost connection to API
Your debug log shows a dnsmasq process running on port 53. This will prevent pihole-FTL (which has embedded dnsmasq) from binding to that port.
Confirm with this command from the Pi terminal:
sudo netstat -nltup | grep 'Proto\|:53 \|:471'
If you see dnsmasq running, then stop that process and disable it, then start FTL.
How do I disable it?
I did sudo service pihole-FTL start after stopping Dnsmasq then I did sudo netstat -nltup | grep 'Proto|:53 |:471' and only PID/Program name showed up
This means it isn't running but why?
No error message was present
What is the output of these commands?
pihole status
for pihole status it is DNS service not running and for sudo netstat -nltup | grep 'Proto|:53 |:471' it has no programs running
What is the ouput of the following commands from the Pi terminal (first should have no output):
sudo service pihole-FTL restart
pihole-FTL.service - LSB: pihole-FTL daemon
Active: active (exited) since Mon 2020-04-20 16:12:58 PDT; 13s ago
Process: 2576 ExecStart=/etc/init.d/pihole-FTL start (code=exited, status=0/SU
Apr 20 16:12:57 raspberrypi systemd[1]: Starting LSB: pihole-FTL daemon...
Apr 20 16:12:57 raspberrypi pihole-FTL[2576]: Not running
Apr 20 16:12:57 raspberrypi su[2600]: (to pihole) root on none
Apr 20 16:12:57 raspberrypi su[2600]: pam_unix(su:session): session opened for u
Apr 20 16:12:58 raspberrypi pihole-FTL[2576]: dnsmasq: cannot open or create lea
Apr 20 16:12:58 raspberrypi su[2600]: pam_unix(su:session): session closed for u
Apr 20 16:12:58 raspberrypi systemd[1]: Started LSB: pihole-FTL daemon.
The output of these three lines is cut off. Is there more on your display?
yes
er this is what I have
Try this command and see if the rest of the output appears:
sudo systemctl status --full --no-pager pihole-FTL
I got it
root@raspberrypi:/home/pi# sudo systemctl status --ful --no-pager pihole-FTL
ā pihole-FTL.service - LSB: pihole-FTL daemon
Active: active (exited) since Mon 2020-04-20 16:12:58 PDT; 17min ago
Process: 2576 ExecStart=/etc/init.d/pihole-FTL start (code=exited, status=0/SUCCESS)
Apr 20 16:12:57 raspberrypi su[2600]: pam_unix(su:session): session opened for user pihole by (uid=0)
Apr 20 16:12:58 raspberrypi pihole-FTL[2576]: dnsmasq: cannot open or create lease file /var/lib/misc/dnsmasq.leases: Permission denied
Apr 20 16:12:58 raspberrypi su[2600]: pam_unix(su:session): session closed for user pihole
What is the output of this command from the Pi terminal:
pihole-FTL dnsmasq-test
dnsmasq: syntax check OK
The file /var/lib/misc/dnsmasq.leases is not a Pi-hole file, and may be a vestige of the old dnsmasq that was running. I'm not sure how Pi-hole is even finding that file, but let's take a look at all your dnsmasq configuration. What is the output of this command which will show all the non-commented entries in the /etc/dnsmasq directory:
sudo grep -v '#\|^$' -R /etc/dnsmasq.*
literally nothing but when I hit enter i get a >
and it looks like this now
Very odd. Let's try running a repair to Pi-hole.
pihole -r and select the "repair" option.
i have tried that multiple times now
Let's look here then. It is highly unusual for that directory to be empty. It should have at minimum a file 01-pihole.conf , as this is installed by Pi-hole.
ls -lha /etc/dnsmasq.d
it has stuff in it
total 24K
drwxr-xr-x 2 root root 4.0K Apr 20 14:11 .
drwxr-xr-x 118 root root 12K Apr 20 14:11 ..
-rw-r--r-- 1 root root 1.5K Apr 20 14:11 01-pihole.conf
-rw-r--r-- 1 root root 117 Feb 12 15:51 custom-dnsmasq.conf
