Hi Guys,
I am fairly new to this. I have installed pihole on my raspberry pi and for some reason, I cannot get FTL to work. I have been all over the web to try to find the issue and cannot seem to figure it out. What I get when I run service pihole-FTL status is:
pihole-ftl.service
Loaded: not-found (Reason: No such file or directory)
Active: inactive (dead)
I have tried repair and completely re-configuring everything even re-installing debian from scratch.
debug token: ld9ascd0ks
Also, the web interface says FTL offline
jreiner110:
ld9ascd0ks
Pi-hole v3.3+ is not supported on Jessie:
Update: 2018-08-06
As of v4.0, Pi-hole ships with _FTL_DNS, our fork of dnsmasq, which should restore compatibility with Raspbian Jessie. We still recommend installing a newer OS as Jessie is EOL anyway.
By default, Raspbian Jessie only supports dnsmasq v2.72, which does not work with the log-queries=extra flag, which is required for Pi-hole v3.3+. You may see error messages such as:
dnsmasq: extraneous parameter at line 37 of /etc/dnsmasq.d/01-pihole.conf
failed!
There are two options…
Originally published at: Pi-hole v3.3 Released: It’s “Extra” Special – Pi-hole
Update 2018-02-20 18:05
Hi All, After a few days of pulling out our hair and troubleshooting this whitelisting issue that some of you have reported, we're finally getting to the bottom of it.
The good news is, whitelisting is not completely broken. You can still whitelist domains from the cli with no issues by calling pihole -w [domain-to-whitelist]. The issue only affects whitelisting from the admin page (whit…
You have a few options:
Install fresh or update to Strech and then re-install Pi-hole
if you want to run a different version of Pi-hole, it is possible to install an older version. Typically, we release all three components of Pi-hole at the same time (Core, Web, and FTL), so you'll usually want to install version from the same "release."
For example, we ran into some issues with v3.3 and dnsmasq compatibility with some systems, so some users needed to revert to v3.2.1 (Core and Web) but as part of the 3.2.1 "release," the latest version of FTL was 2.13.2.
Because we version e…
Update: 2018-08-06
Please note that this tutorial is only meant for Rasbian Jessie, although it might (to some extend) also help with similar issues on other Debian versions. Do this at your own risk (however, the likeliness of a failure is rather small in our opinion).
First step: Download more recent versio…
Originally published at: Help Us Beta Test FTLDNS – Pi-hole
In case you missed it , FTLDNS is Pi-hole's Faster Than Light (FTL) daemon combined with a DNS/DHCP server (our fork of dnsmasq). So instead of installing dnsmasq as a dependency, we will be distributing all services in a single binary. This will allow us to hook into dnsmasq's functionality at a code- level, as well as ensuring that you are using the latest stable version of the resolver and receive, e.g., important bu…
or reinstall Pi-hole on a more modern operating system such as Debain/Raspbian Stretch.
system
Closed
June 3, 2018, 11:25am
4
