FTL engine not installed latest everything SOLVED
Pihole installs cleanly
RPI2 latest updated stretch installing pihole using curl pipe bash command it does not install FTL throwing
"Error: Unable to get latest release location from GitHub"
Then other network stuff seems to break cannot upload tokens, cannot resolve github, cannot install another curl pipe bash app am able to ping 8.8.8.8
Cant upload debug log
HOWEVER after reading around I looked in resolv.conf
There were only two # lines nothing that started with nameserver.
So I added the line nameserver 8.8.8.8
Then ran pihole -r
Success it then downloaded and installed FTL.
I have close to zero understanding of how the pi accesses the internet but suspect the issues I have been having were beacuse the resolv.conf file had no nameserver line?
Anyway problem now solved if others are having similar issues.
Basically if the installer or updater fails partway through this behaviour can occur. I'm happy you found the solution!
For those who are new to Linux , these are the steps I used to solve the same problem:
pi@raspberrypi:~ $ sudo nano /etc/resolv.conf
--- > Paste in google’s nameserver 8.8.8.8
Save and exit nano
pi@raspberrypi:~ $ cat /etc/resolv.conf
Generated by dhcpcd
/etc/resolv.conf.head can replace this line
/etc/resolv.conf.tail can replace this line
nameserver 8.8.8.8
pi@raspberrypi:~ $
pi@raspberrypi:~ $ pihole -r
--- > Existing Install Detected
--- > Choose Repair (This will retain existing settings)
--- > Hit Tab to move to the OK button. Press ENTER key
