The issue I am facing:
Only showing 2 clients firewalla and localhost.
Details about my system:
installed on firewalla blue What I have changed since installing Pi-hole:
Checked
Added Use Conditional Forwarding and added
IP of your router 192.168.1.1 and local domain name lan1.
** [ DIAGNOSING ]: Networking
192.168.174.1/24 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
192.168.1.107/24 matches the IP found in /etc/pihole/setupVars.conf
How/where can I remove it, and can I assume you are referring to 192.168.174.1 as the "extra"? This is the default IP address of the firewalla overlay network, I didn't enter it during the Pi-hole setup so I'm not understanding how it got assigned and how to correct that?
Firewalla is running in DHCP mode now, do I have to change this? I'd rather not.
Please, keep it simple please, this is all new to me. Thanks!
