First install :FTL is offline
[Replace this text with what you think should be happening]
Normal running
Activity
Despite the various research and correction tests:
pi-hole does not work, no request
FTL is offline
#pihole-FTL
dnsmasq: failed to create listening socket for port 53: Address already in use
Hi
q4q20jccs9
Your debug log shows another DNS process already running on port 53, so pihole-FTL cannot bind to that port.
[53] is in use by connmand (https://discourse.pi-hole.net/t/hardware-software-requirements/273#ports)
You are running an unsupported OS as well. Updating to a supported version (I.e. Stretch or Buster) should resolve this problem.
[✓] Debian GNU/Linux 8 (jessie)
Conman is acting as a DNS proxy conflicting with the pihole-FTL binary.
Checkout the "--nodnsproxy" directive on the man page:
I believe Jessie still uses System-V to manage services/daemons.
Look for a connmand Bash script in below folder:
/etc/init.d/
Edit the script file manually and add that "--nodnsproxy" argument to the line with the connmand executable (which connmand).
Restart conmand:
sudo service <CONNMAND_SCRIPT_NAME> restart
Or
sudo /etc/init.d/<CONNMAND_SCRIPT_NAME> restart
Restart Pi-hole:
sudo service pihole-FTL restart
Or:
sudo /etc/init.d/pihole-FTL restart
And check ports used by Pi-hole:
sudo netstat -nltup | grep 'Proto\|:53 \|:67 \|:80 \|:471[1-8] '
Note that Jessie is no longer supported either by Raspbian or by Pi-hole.
https://endoflife.software/operating-systems/linux/debian
Hello,
PI-hole is now operational
FTL OK
thank you for the information
My changes :
Create the folder /etc/systemd/system/connman.service.d/ and add the file disable_dns_proxy.conf:
/etc/systemd/system/connman.service.d/disable_dns_proxy.conf
[Service]
ExecStart=
ExecStart=/usr/bin/connmand -n --nodnsproxy
