fresh install, raspbian x64 (03mat2023), Linux raspberrypi 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 GNU/Linux
installed pihole v5; than
echo "development-v6" | sudo tee /etc/pihole/ftlbranch
pihole checkout core development-v6
pihole checkout web development-v6
works, but immediately have
Core vDev (development-v6, 96640ea2)FTL vDev (development-v6, f9e6e55a)· Update available!
Web interface vDev (development-v6, d64dc0d7)· Update available!
pihole -up says: Everything is up to date!
error on pihole commands
sudo pihole -a -p (change password, according to login help) gives help screen, this needs to be changed into
pihole setpassword
pihole -g error:
pihole -g
/usr/local/bin/pihole: line 30: /etc/pihole/versions: Permission denied
question...
/etc/pihole/01-pihole.conf is gone.
I used to change (required for my setup) "interface eth0" into
listen-address=192.168.2.57
listen-address=2a02:xxxx:yyyy:zzzz:f8ca:2bc4:67b7:6263
listen-address=127.0.0.1
listen-address=::1
how do I achieve this, using the toml file (disable interface setting and enable listen-address settings.
question...
is this the latest version? the web interface has less options than the v5 version.
not a pro here but look at the interface = "" in pihole.toml
says to enter a valid interface name
then under it you can specify the listening modes.
Im also trying to figure out permission issues but im on docker.....
jfb
October 10, 2023, 3:59pm
3
The web interface is lagging.
pihole -up
will pull the latest versions, so use this as your daily update, and ignore the web interface for now.
This should be the case, did you select Expert Modus in the settings page? All endpoints should be available.
DL6ER
October 11, 2023, 8:10pm
7
jpgpi250:
question...
listen-address=::1
This manual change of 01-pihole.conf
was in conflict with any Pi-hole settings and cannot easily be replicated with v6.0. You should put this into a dedicated file somewhere in /etc/dnsmasq.d/xyz.conf
and remove the automatically added interface bit in /etc/pihole/dnsmasq.conf
https://github.com/pi-hole/FTL/pull/1656
This PR adds a new settings option dns.listeningMode = "NONE"
that you can set to ensure Pi-hole does not mess with what you set in your auxiliary config file (your manually added listen-address
lines).
DL6ER
October 12, 2023, 4:16pm
8
The PR has been merged, the NONE
option will become available in about half an hour (branch development-v6
