Error: can't bind socket: Address already in use for 127.0.0.1 port 5335
System: Pi 2B with Raspios Bullseye + PiHole + Unbound
Unbound -v should report no warning.
Unbound -v reports a port error but system works fine.
"error: can't bind socket: Address already in use for 127.0.0.1 port 5335"
https://tricorder.pi-hole.net/UcMfR6oU/
Replies in english or german are welcome.
What is the complete output of the following command from the Pi terminal:
pi@x-pihole:~ $ sudo grep -v '#\|^$' -R /etc/unbound/unbound.conf*
/etc/unbound/unbound.conf.d/pi-hole.conf:    do-ip6: yes
/etc/unbound/unbound.conf.d/pi-hole.conf:    prefer-ip6: yes
/etc/unbound/unbound.conf.d/pi-hole.conf:    edns-buffer-size: 1472
/etc/unbound/unbound.conf.d/pi-hole.conf:    num-threads: 2
/etc/unbound/unbound.conf.d/pi-hole.conf:    serve-expired: yes
/etc/unbound/unbound.conf.d/pi-hole.conf:    msg-cache-size: 128m
/etc/unbound/unbound.conf.d/pi-hole.conf:    rrset-cache-size: 256m
/etc/unbound/unbound.conf.d/pi-hole.conf:    auth-zone:
/etc/unbound/unbound.conf.d/pi-hole.conf:       name: "."
/etc/unbound/unbound.conf.d/pi-hole.conf:fallback-enabled: yes
/etc/unbound/unbound.conf.d/pi-hole.conf:       for-downstream: no
/etc/unbound/unbound.conf.d/pi-hole.conf:       for-upstream: yes
/etc/unbound/unbound.conf.d/pi-hole.conf:       zonefile: "/var/lib/unbound/root.zone"
This is not the expected behavior. That is just the way unbound works, apparently. From my install:
unbound -v
[1673455265] unbound[29700:0] notice: Start of unbound 1.13.1.
[1673455265] unbound[29700:0] error: can't bind socket: Address already in use for 127.0.0.1 port 5335
[1673455265] unbound[29700:0] fatal error: could not open ports
You can check configuration with the following, which I anticipate will show no errors:
unbound-checkconf
And check unbound status, which I also anticipate will show no problems:
sudo service unbound status
You're right. No errors and status "active (running)"
I was just a bit worried about the Unbound message.
Thanks !
