I had 466 184 addresses in the list, and after updating to the latest version, I only have:198 240
Why or what please?
LOG:
[✓] Consolidating blocklists
[✓] Extracting domains from blocklists
[i] Number of domains being pulled in by gravity: 466184
[✓] Removing duplicate domains
[i] Number of unique domains trapped in the Event Horizon: 198240
[i] Number of blocklist source domains being added to the whitelist: 12
[i] Number of whitelisted domains: 113
[i] Number of blacklisted domains: 61
[i] Number of wildcard blocked domains: 4
[✓] Parsing domains into hosts format
[✓] Cleaning up stray matter
[✓] DNS service is running
It appears that many of them were duplicates. We did make some changes to gravity that make it more accurate (there may have been some duff entries in your gravity.list before hand), could you provide a debug token so we can take a closer look?
I actually see the same number of domains using your adlists.list file between the previous version and the newest version of Pi-hole... are you sure you had 466184 before the update?
Pi-hole 3.3:
[i] Number of domains being pulled in by gravity: 466,183
[i] Number of unique domains trapped in the Event Horizon: 198,240
[i] Number of whitelisted domains: 23
[i] Number of blacklisted domains: 21
[i] Number of wildcard blocked domains: 3
[✓] Force-reloading DNS service
Pi-hole 3.2.1:
I don't think this is an issue with 3.3, as I get the same number of domains on 3.2.1.
One thing I did noticed (on both runs) was that two of the lists did not download:
[i] Target: www.joewein.net (dom-bl-base.txt)
[✗] Status: Forbidden
[✗] List download failed: no cached list available
could be that...
edit: Those are both the same list, you have it in your adlists.list file twice
As I mentioned before, The number of domains doesn't look to be an issue with the version of Pi-hole, I've tried it on both the previous and the current versions and I get the same results. May be that the lists have changed.
