I'm essentially experiencing the same behavior detailed in this topic: Dnsmasq not starting - Ubuntu 18.04
I was not able to install pi-hole until editing /etc/systemd/resolved.conf and setting "DNSStubListener=no"
After restarting systemd-resolved, I was able to install pi-hole.
Unfortunately, this results in the consequence of being unable to resolve local IP addresses (I'm using dnsmasq on my router running dd-wrt, which resolves local clients to 'hostname.lan'), so all clients appear in the Pi-hole Admin Console by IP address.
If I stop pihole-FTL, set DNSStubListener=yes, restart systemd-resolved, and then start pinhole-FTL, I can actually see the resolved local hostnames show up in the Admin Console. However, pi-hole will not filter in this state due to dnsmasq-base running on port 53.
Is there some way I can get pi-hole running while still being able to resolve local hostnames?
5o0e6r7nq5
