root@blackPI:~# service pihole-FTL restart
root@blackPI:~# sudo systemctl status --full --no-pager pihole-FTL
ā pihole-FTL.service - LSB: pihole-FTL daemon
Active: active (exited) since Sun 2022-07-10 10:37:23 CEST; 19s ago
Process: 10306 ExecStart=/etc/init.d/pihole-FTL start (code=exited, status=0/SUCCESS)
CPU: 66ms
Jul 10 10:37:22 blackPI systemd[1]: Starting LSB: pihole-FTL daemon...
Jul 10 10:37:22 blackPI pihole-FTL[10306]: Not running
Jul 10 10:37:22 blackPI su[10334]: (to pihole) root on none
Jul 10 10:37:22 blackPI su[10334]: pam_unix(su:session): session opened for user pihole(uid=999) by (uid=0)
Jul 10 10:37:23 blackPI su[10334]: pam_unix(su:session): session closed for user pihole
Jul 10 10:37:23 blackPI systemd[1]: Started LSB: pihole-FTL daemon.
root@blackPI:~#
I also tried a repair-installation:
pihole -r
Nothing chanced
So I suppose, uninstall - reinstall wouldnt chance anything
No Firewall is installed
IPv6 is disabled
root@blackPI:~# netstat -nltup
Aktive Internetverbindungen (Nur Server)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 10.0.9.1:14434 0.0.0.0:* LISTEN 840/qbittorrent-nox
tcp 0 0 0.0.0.0:8888 0.0.0.0:* LISTEN 1042/perl
tcp 0 0 127.0.0.1:14434 0.0.0.0:* LISTEN 840/qbittorrent-nox
tcp 0 0 0.0.0.0:666 0.0.0.0:* LISTEN 991/apache2
tcp 0 0 0.0.0.0:667 0.0.0.0:* LISTEN 991/apache2
tcp 0 0 0.0.0.0:45678 0.0.0.0:* LISTEN 991/apache2
tcp 0 0 192.168.98.1:14434 0.0.0.0:* LISTEN 840/qbittorrent-nox
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 9755/lighttpd
tcp 0 0 127.0.0.1:39677 0.0.0.0:* LISTEN 3498/cockpit-bridge
tcp 0 0 192.168.3.102:14434 0.0.0.0:* LISTEN 840/qbittorrent-nox
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 748/sshd: /usr/sbin
tcp 0 0 0.0.0.0:2525 0.0.0.0:* LISTEN 1834/master
tcp 0 0 0.0.0.0:55554 0.0.0.0:* LISTEN 809/openvpn
tcp 0 0 0.0.0.0:55552 0.0.0.0:* LISTEN 638/stunnel4
tcp 0 0 127.0.0.1:3306 0.0.0.0:* LISTEN 801/mysqld
tcp 0 0 192.168.99.1:14434 0.0.0.0:* LISTEN 840/qbittorrent-nox
tcp 0 0 10.0.8.1:14434 0.0.0.0:* LISTEN 840/qbittorrent-nox
tcp 0 0 0.0.0.0:5900 0.0.0.0:* LISTEN 743/vncserver-x11-c
tcp6 0 0 :::9090 :::* LISTEN 1/init
tcp6 0 0 :::80 :::* LISTEN 9755/lighttpd
tcp6 0 0 :::22 :::* LISTEN 748/sshd: /usr/sbin
tcp6 0 0 :::2525 :::* LISTEN 1834/master
tcp6 0 0 :::7777 :::* LISTEN 840/qbittorrent-nox
tcp6 0 0 :::5900 :::* LISTEN 743/vncserver-x11-c
udp 0 0 0.0.0.0:55553 0.0.0.0:* 811/openvpn
udp 0 0 0.0.0.0:45536 0.0.0.0:* 484/avahi-daemon: r
udp 0 0 0.0.0.0:530 0.0.0.0:* 29171/iodined
udp 0 0 0.0.0.0:51820 0.0.0.0:* -
udp 0 0 0.0.0.0:5353 0.0.0.0:* 484/avahi-daemon: r
udp 0 0 0.0.0.0:68 0.0.0.0:* 345/dhclient
udp 0 0 192.168.99.1:14434 0.0.0.0:* 840/qbittorrent-nox
udp 0 0 192.168.98.1:14434 0.0.0.0:* 840/qbittorrent-nox
udp 0 0 10.0.9.1:14434 0.0.0.0:* 840/qbittorrent-nox
udp 0 0 10.0.8.1:14434 0.0.0.0:* 840/qbittorrent-nox
udp 0 0 192.168.3.102:14434 0.0.0.0:* 840/qbittorrent-nox
udp 0 0 127.0.0.1:14434 0.0.0.0:* 840/qbittorrent-nox
udp6 0 0 :::51820 :::*
before Update of pihole, I updated these raspian-packages via apt update and apt upgrade
Start-Date: 2022-07-09 09:12:32
Commandline: apt upgrade
Upgrade: firmware-brcm80211:armhf (1:20210315-3+rpt6, 1:20210315-3+rpt7), libavdevice58:armhf (7:4.3.4-0+deb11u1+rpt1, 7:4.3.4-0+deb11u1+rpt2), ffmpeg:armhf (7:4.3.4-0+deb11u1+rpt1, 7:4.3.4-0+deb11u1+rpt2), libpostproc55:armhf (7:4.3.4-0+deb11u1+rpt1, 7:4.3.4-0+deb11u1+rpt2), libavcodec58:armhf (7:4.3.4-0+deb11u1+rpt1, 7:4.3.4-0+deb11u1+rpt2), firmware-realtek:armhf (1:20210315-3+rpt6, 1:20210315-3+rpt7), firmware-libertas:armhf (1:20210315-3+rpt6, 1:20210315-3+rpt7), libavutil56:armhf (7:4.3.4-0+deb11u1+rpt1, 7:4.3.4-0+deb11u1+rpt2), firmware-misc-nonfree:armhf (1:20210315-3+rpt6, 1:20210315-3+rpt7), libswscale5:armhf (7:4.3.4-0+deb11u1+rpt1, 7:4.3.4-0+deb11u1+rpt2), libswresample3:armhf (7:4.3.4-0+deb11u1+rpt1, 7:4.3.4-0+deb11u1+rpt2), libavformat58:armhf (7:4.3.4-0+deb11u1+rpt1, 7:4.3.4-0+deb11u1+rpt2), libavresample4:armhf (7:4.3.4-0+deb11u1+rpt1, 7:4.3.4-0+deb11u1+rpt2), libavfilter7:armhf (7:4.3.4-0+deb11u1+rpt1, 7:4.3.4-0+deb11u1+rpt2)
End-Date: 2022-07-09 09:13:22
Is there anything which can caused the problem?
everything was ok, then
pihole up
then the problem was occured
//EDIT:
new log from today, after a new apt update and apt upgrade and reboot
https://tricorder.pi-hole.net/mADg1Qm1/
//EDIT:
have you seen these things in debug-log:
2022-07-09 09:45:31: mod_fastcgi.c.487) FastCGI-stderr:PHP Warning: fopen(/var/log/pihole/pihole.log): failed to open stream: Permission denied in /var/www/html/admin/scripts/pi-hole/php/tailLog.php on line 21
[2022-07-09 00:29:22.180 1522M] ERR: Port mismatch for 9.9.9.11: we derived 53, dnsmasq told us 48
[2022-07-09 00:29:22.180 1522M] ERR: Port mismatch for 149.112.112.11: we derived 53, dnsmasq told us 48
2022-07-09 09:21:23: configfile.c.1142) WARNING: unknown config-key: alias.url (ignored)
