Hi Help team,
PiHole installs correctly
Error:
DNS resolution is currently unavailable
There was an error uploading your debug log.
Steps followed to try and fix the problem.
Followed the threads for:
Pihole installs, starts, and DNS resolution works both from the command line, and from remote queries
Install gets this far and then borks:
[i] Restarting services...
[✓] Enabling pihole-FTL service to start on reboot...
[✓] Starting pihole-FTL service...
[✓] Deleting existing list cache
[✗] DNS resolution is currently unavailable
[✗] DNS resolution is not …
I tried to install PiHole on 2 different pc's behind same DD-WRT router; first pc, was an intel atom, running an old ubuntu 16.04; second one, was running a fresh install of ubuntu 18.04 then i switched to debian 9.
I keep getting this error at install on both devices
Blockquote
[✓] Restarting pihole-FTL servi…
https://github.com/pi-hole/pi-hole/issues/1800
All of these more or less follow the same troubleshooting procedure but none of them has resolved any of the problems I am having.
If it's easier I'm more than happy for someone to Teamviewer or screen share my computer to help fix this faster.
Thanks,
Austin
jfb
October 5, 2019, 10:40am
2
This will temporarily reset the nameserver on the Pi to bypass Pi-Hole DNS.
sudo nano /etc/resolv.conf
edit nameserver 127.0.0.1 to nameserver 9.9.9.9 or your preferred third party DNS service, save and exit
Run pihole -d and upload the debug log, and post the token here.
Hi jfb,
Thanks for helping out.
I have already tried that as it was in the other 4 threads I linked but it still brings up the same error message.
Here is a screenshot of what I am seeing exactly at the end of the pihole -d command.
If you would like more screenshots or a video I am happy to get anything needed. Or as I said I am more than happy for you to screenshare via Discord or use Teamviewer to help fix the issue.
Thanks,
Austin
Hi jfb,
I have sent the file through.
Thanks,
Austin
jfb
October 5, 2019, 2:23pm
7
Your debug log shows your gravity list is empty. Rebuild gravity with this command from the Pi terminal:
pihole -g -f
When I run that it bring up the original issue.
system
Closed
October 26, 2019, 2:26pm
9
