Every time i restart my Ubuntu 18.0.4 Pi-hole i cannot access the internet until i manually click "Restart dnsmasq" button in the WebUI. Or if im in the server the internet will only come back when i run "pihole restartdns"
I've also tried to use a crontab task to run "pihole restartdns" with no luck: @reboot sleep 30 && pihole restartdns
Does anyone have any ideas why the DNS is not working after a reboot of the Ubuntu server?
Here's my debug tokem: ayxxw9uunn
There have been some problems with this version of Ubuntu (Redirecting...)
[✓] Ubuntu 18.04.1 LTS
Related threads:
Your debug log shows multiple IP addresses which may be contributing:
192.168.86.47/24 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
192.168.86.11/24 matches the IP found in /etc/pihole/setupVars.conf
*:80 lighttpd (IPv4)
*:80 lighttpd (IPv6)
*:22 sshd (IPv4)
*:22 sshd (IPv6)
192.168.86.47:53 pihole-FTL (IPv4)
127.0.0.1:53 pihole-FTL (IPv4)
And this indicates what you are already seeing - cannot resolve DNS from the Pi-Hole IP.
[✓] 6g7ts9dg9q.centade.com is 0.0.0.0 via localhost (127.0.0.1)
[✗] Failed to resolve 6g7ts9dg9q.centade.com via Pi-hole (192.168.86.11)
