DNS and FTL not running
Hi, I updated to 3.3 recently and now my dnsmasq fails to start (extraneous parameter at line 37 of /etc/dnsmasq.d/01-pihole.conf) and FTL seems not to be running either. Any advice?
my debug token is: 2mv604btjj
Thanks in advance
Pi-hole v3.3 and v3.3.1 are not supported on Jessie with dnsmasq < 2.73:
You have a few options:
  • Install or update to Raspbian Stretch
  • Update dnsmasq to a version > 2.72
  • Join the FTLDNS beta
  • Downgrade to an older version of Pi-hole
Working perfectly, thank you!
Other option would have been fixing the dnsmasq start script like discussed in
