I'm running Pi-hole on a Pi 1 and it is acting as my DHCP server. It has worked great for a long time on v4 and I recently updated to v5. After upgrading, I'm no longer able to use the temporary disable feature from the web interface.
I expect clicking disable to stop blocking any domains for the duration of the disable period and then resume blocking once the disable period is over.
Pi-hole v5.1.2
Web interface v5.1.1
FTL v5.2
All DNS resolution ends and no websites are accessible. The Pi-hole is no longer accessible via pi.hole/admin and only via direct IP address. DNS resolution does not come back after the disable period ends. I have to reboot the Pi-hole in order to regain DNS resolution.
I've found this reported before on Reddit: 1, 2, 3, 4, 5
And here: 1, 2
That last link suggests that the behavior was fixed in FTL v5.2. However, I am still experiencing the issue.
