DHCP setup didn't work - Entire network went dark
When I disable the DHCP server function on my router, I should still be able to access the pi-hole admin console at its previous IP address from my chrome browser on Windows 10.
When I disable the DHCP server function on my D-Link DIR885L router, I can no longer access the pi-hole server at its previous IP address (192.168.0.119) in order to turn on the DHCP server function in it. In fact, I can't access anything, even the router at 192.168.0.1. I had to reset the router to regain control. What am I missing here?
I was trying to follow the instructions here: How do I use Pi-hole's built in DHCP server (and why would I want to)?
Thanks for your help.
Make sure Pi-hole is assigned a static IP address making it independent from the router DHCP:
pi@noads:~ $ journalctl -u dhcpcd
Sep 08 22:28:43 noads.dehakkelaar.nl systemd[1]: Starting dhcpcd on all interfaces...
Sep 08 22:28:43 noads.dehakkelaar.nl dhcpcd[30082]: dev: loaded udev
Sep 08 22:28:43 noads.dehakkelaar.nl dhcpcd[30082]: DUID xx:xx:xx
Sep 08 22:28:43 noads.dehakkelaar.nl dhcpcd[30082]: eth0: IAID xx:xx:xx:xx
Sep 08 22:28:43 noads.dehakkelaar.nl dhcpcd[30082]: eth0: using static address 10.0.0.2/24
Sep 08 22:28:43 noads.dehakkelaar.nl dhcpcd[30082]: eth0: adding route to 10.0.0.0/24
Sep 08 22:28:43 noads.dehakkelaar.nl dhcpcd[30082]: eth0: adding default route via 10.0.0.1
Sep 08 22:28:43 noads.dehakkelaar.nl dhcpcd[30082]: forked to background, child pid 30098
Sep 08 22:28:43 noads.dehakkelaar.nl systemd[1]: Started dhcpcd on all interfaces.
Sep 08 22:28:43 noads.dehakkelaar.nl dhcpcd[30098]: eth0: soliciting an IPv6 router
Sep 08 22:28:55 noads.dehakkelaar.nl dhcpcd[30098]: eth0: no IPv6 Routers available
Whats IP ?
ip -4 a
And whats in below file:
tail -20 /etc/dhcpcd.conf
EDIT: And post a debug token here if you want to have the devs/mods to take a closer look ?
I think it already has a static IP address. Doesn't the fact that I couldn't even access the router at 192.168.0.1 indicate a more fundamental problem?
Here is the output from your suggestions: (Will include debug token in next post.)
Apr 18 01:25:04 raspberrypi systemd[1]: Started dhcpcd on all interfaces.
Apr 18 01:25:06 raspberrypi dhcpcd-run-hooks[360]: wlan0: starting wpa_supplicant
Apr 18 01:25:08 raspberrypi dhcpcd[332]: wlan0: waiting for carrier
Apr 18 01:25:08 raspberrypi dhcpcd[332]: wlan0: carrier acquired
Apr 18 01:25:08 raspberrypi dhcpcd[332]: DUID 00:01:00:01:22:69:5a:f4:b8:27:eb:1e:ee:59
Apr 18 01:25:08 raspberrypi dhcpcd[332]: wlan0: IAID eb:1e:ee:59
Apr 18 01:25:08 raspberrypi dhcpcd[332]: wlan0: adding address fe80::eca3:92a8:e698:f72e
Apr 18 01:25:09 raspberrypi dhcpcd[332]: wlan0: carrier lost
Apr 18 01:25:09 raspberrypi dhcpcd[332]: wlan0: deleting address fe80::eca3:92a8:e698:f72e
Apr 18 01:25:09 raspberrypi dhcpcd[332]: wlan0: carrier acquired
Apr 18 01:25:09 raspberrypi dhcpcd[332]: wlan0: IAID eb:1e:ee:59
Apr 18 01:25:09 raspberrypi dhcpcd[332]: wlan0: adding address fe80::83ed:6d95:cb6b:b8e1
Apr 18 01:25:09 raspberrypi dhcpcd[332]: wlan0: soliciting an IPv6 router
Apr 18 01:25:09 raspberrypi dhcpcd[332]: wlan0: soliciting a DHCP lease
Apr 18 01:25:10 raspberrypi dhcpcd[332]: wlan0: offered 192.168.0.119 from 192.168.0.1
Apr 18 01:25:10 raspberrypi dhcpcd[332]: wlan0: probing address 192.168.0.119/24
Apr 18 01:25:11 raspberrypi dhcpcd[332]: wlan0: Router Advertisement from fe80::928d:78ff:fe66:4030
Apr 18 01:25:11 raspberrypi dhcpcd[332]: wlan0: adding address 2605:6000:ee80:1d01:432c:4269:2321:69c7/64
Apr 18 01:25:11 raspberrypi dhcpcd[332]: wlan0: adding route to 2605:6000:ee80:1d01::/64
Apr 18 01:25:11 raspberrypi dhcpcd[332]: wlan0: adding default route via fe80::928d:78ff:fe66:4030
Apr 18 01:25:11 raspberrypi dhcpcd[332]: wlan0: requesting DHCPv6 information
Apr 18 01:25:15 raspberrypi dhcpcd[332]: wlan0: leased 192.168.0.119 for 604800 seconds
Apr 18 01:25:15 raspberrypi dhcpcd[332]: wlan0: adding route to 192.168.0.0/24
Apr 18 01:25:15 raspberrypi dhcpcd[332]: wlan0: adding default route via 192.168.0.1
Sep 07 04:49:11 raspberrypi dhcpcd[332]: wlan0: deleting default route via fe80::928d:78ff:fe66:4030
Sep 07 04:49:39 raspberrypi dhcpcd[332]: wlan0: adding address 2605:6000:101e:926:fb2a:ed3f:2234:d649/64
Sep 07 04:49:39 raspberrypi dhcpcd[332]: wlan0: adding route to 2605:6000:101e:926::/64
Sep 07 04:49:39 raspberrypi dhcpcd[332]: wlan0: adding default route via fe80::928d:78ff:fe66:4030
Sep 07 05:38:18 raspberrypi dhcpcd[332]: wlan0: deleting default route via fe80::928d:78ff:fe66:4030
Sep 07 05:38:49 raspberrypi dhcpcd[332]: wlan0: adding default route via fe80::928d:78ff:fe66:4030
Sep 07 06:00:05 raspberrypi dhcpcd[332]: wlan0: deleting default route via fe80::928d:78ff:fe66:4030
Sep 07 06:00:38 raspberrypi dhcpcd[332]: wlan0: adding default route via fe80::928d:78ff:fe66:4030
Sep 07 06:49:14 raspberrypi dhcpcd[332]: wlan0: expired address 2605:6000:ee80:1d01:432c:4269:2321:69c7/64
Sep 07 06:49:14 raspberrypi dhcpcd[332]: wlan0: deleting route to 2605:6000:ee80:1d01::/64
Sep 08 15:56:33 raspberrypi dhcpcd[332]: wlan0: deleting default route via fe80::928d:78ff:fe66:4030
Sep 08 15:57:05 raspberrypi dhcpcd[332]: wlan0: adding default route via fe80::928d:78ff:fe66:4030
Sep 08 16:29:58 raspberrypi dhcpcd[332]: wlan0: deleting default route via fe80::928d:78ff:fe66:4030
Sep 08 16:30:26 raspberrypi dhcpcd[332]: wlan0: adding default route via fe80::928d:78ff:fe66:4030
Sep 08 16:53:55 raspberrypi dhcpcd[332]: wlan0: deleting default route via fe80::928d:78ff:fe66:4030
Sep 08 16:54:22 raspberrypi dhcpcd[332]: wlan0: adding default route via fe80::928d:78ff:fe66:4030
Sep 08 17:45:44 raspberrypi dhcpcd[332]: wlan0: carrier lost
Sep 08 17:45:44 raspberrypi dhcpcd[332]: wlan0: deleting address 2605:6000:101e:926:fb2a:ed3f:2234:d649/64
Sep 08 17:45:44 raspberrypi dhcpcd[332]: wlan0: deleting default route via fe80::928d:78ff:fe66:4030
Sep 08 17:45:44 raspberrypi dhcpcd[332]: wlan0: deleting route to 2605:6000:101e:926::/64
Sep 08 17:45:45 raspberrypi dhcpcd[332]: wlan0: deleting address fe80::83ed:6d95:cb6b:b8e1
Sep 08 17:45:45 raspberrypi dhcpcd[332]: wlan0: deleting default route via 192.168.0.1
Sep 08 17:45:45 raspberrypi dhcpcd[332]: wlan0: deleting route to 192.168.0.0/24
Sep 08 17:46:33 raspberrypi dhcpcd[332]: wlan0: carrier acquired
Sep 08 17:46:33 raspberrypi dhcpcd[332]: wlan0: confile file changed, expiring leases
Sep 08 17:46:33 raspberrypi dhcpcd[332]: wlan0: IAID eb:1e:ee:59
Sep 08 17:46:33 raspberrypi dhcpcd[332]: wlan0: adding address fe80::83ed:6d95:cb6b:b8e1
Sep 08 17:46:33 raspberrypi dhcpcd[332]: wlan0: probing address 192.168.0.119/24
Sep 08 17:46:34 raspberrypi dhcpcd[332]: wlan0: soliciting an IPv6 router
Sep 08 17:46:38 raspberrypi dhcpcd[332]: wlan0: using static address 192.168.0.119/24
Sep 08 17:46:38 raspberrypi dhcpcd[332]: wlan0: adding route to 192.168.0.0/24
Sep 08 17:46:38 raspberrypi dhcpcd[332]: wlan0: adding default route via 192.168.0.1
Sep 08 17:46:47 raspberrypi dhcpcd[332]: wlan0: no IPv6 Routers available
Sep 08 17:51:18 raspberrypi dhcpcd[332]: wlan0: carrier lost
Sep 08 17:51:19 raspberrypi dhcpcd[332]: wlan0: deleting address fe80::83ed:6d95:cb6b:b8e1
Sep 08 17:51:19 raspberrypi dhcpcd[332]: wlan0: deleting default route via 192.168.0.1
Sep 08 17:51:19 raspberrypi dhcpcd[332]: wlan0: deleting route to 192.168.0.0/24
Sep 08 17:52:01 raspberrypi dhcpcd[332]: wlan0: carrier acquired
Sep 08 17:52:01 raspberrypi dhcpcd[332]: wlan0: IAID eb:1e:ee:59
Sep 08 17:52:01 raspberrypi dhcpcd[332]: wlan0: adding address fe80::83ed:6d95:cb6b:b8e1
Sep 08 17:52:01 raspberrypi dhcpcd[332]: wlan0: probing address 192.168.0.119/24
Sep 08 17:52:01 raspberrypi dhcpcd[332]: wlan0: soliciting an IPv6 router
Sep 08 17:52:06 raspberrypi dhcpcd[332]: wlan0: carrier lost
Sep 08 17:52:06 raspberrypi dhcpcd[332]: wlan0: deleting address fe80::83ed:6d95:cb6b:b8e1
Sep 08 17:52:08 raspberrypi dhcpcd[332]: wlan0: carrier acquired
Sep 08 17:52:08 raspberrypi dhcpcd[332]: wlan0: IAID eb:1e:ee:59
Sep 08 17:52:08 raspberrypi dhcpcd[332]: wlan0: adding address fe80::83ed:6d95:cb6b:b8e1
Sep 08 17:52:08 raspberrypi dhcpcd[332]: wlan0: probing address 192.168.0.119/24
Sep 08 17:52:08 raspberrypi dhcpcd[332]: wlan0: soliciting an IPv6 router
Sep 08 17:52:13 raspberrypi dhcpcd[332]: wlan0: using static address 192.168.0.119/24
Sep 08 17:52:13 raspberrypi dhcpcd[332]: wlan0: adding route to 192.168.0.0/24
Sep 08 17:52:13 raspberrypi dhcpcd[332]: wlan0: adding default route via 192.168.0.1
Sep 08 17:52:21 raspberrypi dhcpcd[332]: wlan0: no IPv6 Routers available
Sep 08 17:56:22 raspberrypi dhcpcd[332]: wlan0: carrier lost
Sep 08 17:56:22 raspberrypi dhcpcd[332]: wlan0: deleting address fe80::83ed:6d95:cb6b:b8e1
Sep 08 17:56:22 raspberrypi dhcpcd[332]: wlan0: deleting default route via 192.168.0.1
Sep 08 17:56:22 raspberrypi dhcpcd[332]: wlan0: deleting route to 192.168.0.0/24
Sep 08 17:59:55 raspberrypi dhcpcd[332]: wlan0: carrier acquired
Sep 08 17:59:55 raspberrypi dhcpcd[332]: wlan0: IAID eb:1e:ee:59
Sep 08 17:59:55 raspberrypi dhcpcd[332]: wlan0: adding address fe80::83ed:6d95:cb6b:b8e1
Sep 08 17:59:55 raspberrypi dhcpcd[332]: wlan0: probing address 192.168.0.119/24
Sep 08 17:59:55 raspberrypi dhcpcd[332]: wlan0: soliciting an IPv6 router
Sep 08 17:59:58 raspberrypi dhcpcd[332]: wlan0: Router Advertisement from fe80::928d:78ff:fe66:4030
Sep 08 17:59:58 raspberrypi dhcpcd[332]: wlan0: adding address 2605:6000:ee83:f01:876f:9b8:b6f9:60a1/64
Sep 08 17:59:58 raspberrypi dhcpcd[332]: wlan0: adding route to 2605:6000:ee83:f01::/64
Sep 08 17:59:58 raspberrypi dhcpcd[332]: wlan0: adding default route via fe80::928d:78ff:fe66:4030
Sep 08 17:59:58 raspberrypi dhcpcd[332]: wlan0: requesting DHCPv6 information
Sep 08 18:00:00 raspberrypi dhcpcd[332]: wlan0: using static address 192.168.0.119/24
Sep 08 18:00:00 raspberrypi dhcpcd[332]: wlan0: adding route to 192.168.0.0/24
Sep 08 18:00:00 raspberrypi dhcpcd[332]: wlan0: adding default route via 192.168.0.1
Sep 08 18:00:54 raspberrypi dhcpcd[332]: wlan0: carrier lost
Sep 08 18:00:55 raspberrypi dhcpcd[332]: wlan0: deleting address 2605:6000:ee83:f01:876f:9b8:b6f9:60a1/64
Sep 08 18:00:55 raspberrypi dhcpcd[332]: wlan0: deleting default route via fe80::928d:78ff:fe66:4030
Sep 08 18:00:55 raspberrypi dhcpcd[332]: wlan0: deleting route to 2605:6000:ee83:f01::/64
Sep 08 18:00:55 raspberrypi dhcpcd[332]: wlan0: deleting address fe80::83ed:6d95:cb6b:b8e1
Sep 08 18:00:55 raspberrypi dhcpcd[332]: wlan0: deleting default route via 192.168.0.1
Sep 08 18:00:55 raspberrypi dhcpcd[332]: wlan0: deleting route to 192.168.0.0/24
Sep 08 18:00:56 raspberrypi dhcpcd[332]: wlan0: carrier acquired
Sep 08 18:00:56 raspberrypi dhcpcd[332]: wlan0: IAID eb:1e:ee:59
Sep 08 18:00:56 raspberrypi dhcpcd[332]: wlan0: adding address fe80::83ed:6d95:cb6b:b8e1
Sep 08 18:00:56 raspberrypi dhcpcd[332]: wlan0: probing address 192.168.0.119/24
Sep 08 18:00:56 raspberrypi dhcpcd[332]: wlan0: soliciting an IPv6 router
Sep 08 18:01:01 raspberrypi dhcpcd[332]: wlan0: using static address 192.168.0.119/24
Sep 08 18:01:01 raspberrypi dhcpcd[332]: wlan0: adding route to 192.168.0.0/24
Sep 08 18:01:01 raspberrypi dhcpcd[332]: wlan0: adding default route via 192.168.0.1
Sep 08 18:01:09 raspberrypi dhcpcd[332]: wlan0: no IPv6 Routers available
Sep 08 18:01:25 raspberrypi dhcpcd[332]: wlan0: Router Advertisement from fe80::928d:78ff:fe66:4030
Sep 08 18:01:25 raspberrypi dhcpcd[332]: wlan0: adding address 2605:6000:ee83:f01:876f:9b8:b6f9:60a1/64
Sep 08 18:01:25 raspberrypi dhcpcd[332]: wlan0: adding route to 2605:6000:ee83:f01::/64
Sep 08 18:01:25 raspberrypi dhcpcd[332]: wlan0: adding default route via fe80::928d:78ff:fe66:4030
Sep 08 18:01:25 raspberrypi dhcpcd[332]: wlan0: requesting DHCPv6 information
Sep 08 18:18:31 raspberrypi dhcpcd[332]: wlan0: deleting default route via fe80::928d:78ff:fe66:4030
Sep 08 18:19:05 raspberrypi dhcpcd[332]: wlan0: adding address 2605:6000:101e:4d1:1681:b165:4a3d:8e14/64
Sep 08 18:19:05 raspberrypi dhcpcd[332]: wlan0: adding route to 2605:6000:101e:4d1::/64
Sep 08 18:19:05 raspberrypi dhcpcd[332]: wlan0: adding default route via fe80::928d:78ff:fe66:4030
Sep 08 20:18:34 raspberrypi dhcpcd[332]: wlan0: expired address 2605:6000:ee83:f01:876f:9b8:b6f9:60a1/64
Sep 08 20:18:34 raspberrypi dhcpcd[332]: wlan0: deleting route to 2605:6000:ee83:f01::/64
lines 41-125/125 (END)
pi@raspberrypi:~ $ ip -4 a
2: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
inet 192.168.0.119/24 brd 192.168.0.255 scope global wlan0
pi@raspberrypi:~ $ tail -20 /etc/dhcpcd.conf
#static ip_address=192.168.0.10/24
#static ip6_address=fd51:42f8:caae:d92e::ff/64
#static routers=192.168.0.1
#static domain_name_servers=192.168.0.1 8.8.8.8 fd51:42f8:caae:d92e::1
It is possible to fall back to a static IP if DHCP fails:
define static profile
#profile static_eth0
#static ip_address=192.168.1.23/24
#static routers=192.168.1.1
#static domain_name_servers=192.168.1.1
fallback to static profile on eth0
#interface eth0
#fallback static_eth0
interface wlan0
static ip_address=192.168.0.119/24
pi@raspberrypi:~ $
The debug token is:
https://tricorder.pi-hole.net/nuslfp3u8m
To be clear, it is currently running in DNS mode, not DHCP mode. DNS mode doesn't work on my D-Link DIR-885L router because it insists on having both primary and secondary DNS addresses. I can't have both addresses point to the same place (e.g. 192.168.0.119). It doesn't accept 0.0.0.0. I've tried using other valid addresses in the network (e.g. 192.168.0.1) but that doesn't work. If I leave the secondary blank, it magically gets filled in by the router.
Above one indicates dhcpcd5 was actually able to assign a static IP.
Yes.
Normal behaviour is for the client to retain its DHCP assigned IP address until the DHCP lease expires.
Do you have other device to browse/ping/run nslookup ?
The order of switching on/off DHCP service on the router/Pi-hole isn't important.
You can switch on DHCP service on Pi-hole first and disable the one on the router later.
When finished switching, reboot your test client so it will renew its DHCP lease.
This could also be a router specific problem like the router blocking DHCP or other safety features.
Check settings!
Use one PC with a static assigned IP address to troubleshoot and use other devices to test DHCP renewal and DNS resolution.
Oh cr.p, do you need IPv6 ?
Most of us dont so we run without IPv6 support.
Don’t need IPv6. I accidently installed with only IPv6 (because the install instruction was “space bar to select” rather than “space bar to DEselect.” And then I went back through the install process and deselected IPv6 but maybe it was still in there. The web-based admin console shows blank for IPv6 address.
Pi-hole Ethernet Interface:
wlan0
Pi-hole IPv4 address:
192.168.0.119/24
Pi-hole IPv6 address:
Pi-hole hostname:
pi-hole
Anyway, is there something I should do to turn this off?
Regards,
Hal Jennings
in Austin, TX - Live Music Capital of the World
www.jenningsweb.us
Turn off dns for IPv6, you can use the IPv4 to resolve IPv6 too.
OK. I got the DHCP server working. I think the key things were to make the PC I'm working from have a static IP address and turning on pi-hole's DHCP server before disabling the router's DHCP server. I also disabled the IPv6 router function. I think pi-hole already has IPv6 disabled, though in the admin console, it shows some IPv6 query types (AAAA) in the dashboard pie chart.
Nice job ... from one former IBM'er to another :wink:
IBM TSS Benelux.
Former product techie.
How did you know that I’m a retired IBMer?!? You’re a pretty good sleuth in addition to being a good techie.
Regards,
Hal Jennings
www.jenningsweb.us
Well, every time you post a reply using your mail client, it adds a footer:
:wink:
I’ve had that footer for decades. You might be the second person who clicked on it. You, sir, are amazing.
Keep up the good work!
Regards,
Hal Jennings
www.jenningsweb.us
