Custom TTL flag for Blacklist items
Now that the Blacklist supports notes, etc. with v5.0 I was wondering if it would be possible to add a custom TTL value to blacklisted domains.
Specifically, certain problem domains on my network query as often as possible, while still respecting the given TTL. I'd love to tell those specific domains to shove off with a ~1d TTL, without changing the local TTL value affecting all other domains.
I totally understand and appreciate the low (2s) default TTL value, but certain domains could benefit from a longer TTL.
There is now a global config that can change the TTL for blocked queries.
@Matt
Is this FR about a general TTL for blacklisted domains or did you want to set a custom TTL for some specific blacklisted domains?
