The issue I am facing:
Getting the error:
;; communications error to 127.0.0.1#5335: timed out
when querying certain domains.
Details about my system:
RP5, with latest PiHole version running unbound.
Configured PiHole to use UnBound.
What's odd, is this works:
> dig +dnssec @127.0.0.1 -p 5335 microsoft.com 9 ✘ ╱ took 15s ╱ with tony@bogey-pi-rp5 ╱ at 20:07:40
; <<>> DiG 9.18.24-1-Debian <<>> +dnssec @127.0.0.1 -p 5335 microsoft.com
; (1 server found)
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 55078
;; flags: qr rd ra; QUERY: 1, ANSWER: 5, AUTHORITY: 0, ADDITIONAL: 1
; EDNS: version: 0, flags: do; udp: 1472
;microsoft.com. IN A
microsoft.com. 3151 IN A 20.231.239.246
microsoft.com. 3151 IN A 20.76.201.171
microsoft.com. 3151 IN A 20.70.246.20
microsoft.com. 3151 IN A 20.236.44.162
microsoft.com. 3151 IN A 20.112.250.133
;; Query time: 0 msec
;; SERVER: 127.0.0.1#5335(127.0.0.1) (UDP)
;; WHEN: Tue Apr 23 20:10:43 PDT 2024
;; MSG SIZE rcvd: 122
BUT, this fails:
> dig +dnssec @127.0.0.1 -p 5335 minisforum.com ✔ ╱ with tony@bogey-pi-rp5 ╱ at 20:07:20
; <<>> DiG 9.18.24-1-Debian <<>> +dnssec @127.0.0.1 -p 5335 minisforum.com
; (1 server found)
However, if I force using 1.1.1.1 as the DNS resolver:
> dig +dnssec @1.1.1.1 -p 53 minisforum.com ✔ ╱ with tony@bogey-pi-rp5 ╱ at 20:10:43
; <<>> DiG 9.18.24-1-Debian <<>> +dnssec @1.1.1.1 -p 53 minisforum.com
; (1 server found)
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 62029
; EDNS: version: 0, flags: do; udp: 1232
;minisforum.com. IN A
minisforum.com. 600 IN A 54.177.249.210
;; Query time: 232 msec
;; SERVER: 1.1.1.1#53(1.1.1.1) (UDP)
;; WHEN: Tue Apr 23 20:12:49 PDT 2024
;; MSG SIZE rcvd: 59
No errors seem to show up in my UnBound log.
> sudo service unbound status ✔ ╱ with tony@bogey-pi-rp5 ╱ at 20:12:49
Loaded: loaded (/lib/systemd/system/unbound.service; enabled; preset: enabled)
Active: active (running) since Tue 2024-04-23 20:02:41 PDT; 11min ago
Docs: man:unbound(8)
Process: 890 ExecStartPre=/usr/libexec/unbound-helper chroot_setup (code=exited, status=0/SUCCESS)
Process: 903 ExecStartPre=/usr/libexec/unbound-helper root_trust_anchor_update (code=exited, status=0/SUCCESS)
Main PID: 905 (unbound)
Tasks: 1 (limit: 9248)
CPU: 432ms
CGroup: /system.slice/unbound.service
└─905 /usr/sbin/unbound -d -p
Apr 23 20:02:40 bogey-pi-rp5 systemd[1]: Starting unbound.service - Unbound DNS server...
Apr 23 20:02:41 bogey-pi-rp5 systemd[1]: Started unbound.service - Unbound DNS server.
EDIT: Add TriCorder Debug: https://tricorder.pi-hole.net/IVF5PVUz/
