*I installed pihole and cloudflared following this guide Redirecting... but the test page shows no doh https://1.1.1.1/help
dietpi virtualbox
dietpi virtualbox
What does the test page show? You can past an image directly into a reply.
Please post the token generated by
Tools > Generate Debug Log
Is DNSSEC enabled in your Pi-hole?
Did you have DNSSEC enabled when running the tests?
EDIT:
You can check the current state in Advanced DNS settings the under Settings | DNS
I don't know... sorry
edit: this test said yes https://dnssec.vs.uni-due.de/
EDIT:
YES Use Dnssec is checked
That might well be the reason then.
It's possible that DNSSEC would interfere with Cloudflare's probing tools. The reason for this could be incorrect DNSSEC signing of the subdomains that Cloudflare uses for the test.
At least that's what unbound's
support said when investigating a similar issue with Cloudflare's failing detection of DoT when DNSSEC is enabled, see Cloudflare DoT and DNSSEC.
Cloudflare then acknowledged the issue as an edge case.
You'd have to consult them for progress on the matter.
In the meantime, try rerunning the test with DNSSEC disabled.
But don't forget to turn it back on afterwards - there is value in establishing authenticity of DNS records
thank you so much, doh was indeed detected by the 1.1.1./help test when dnssec was deactivated
