I appreciate the help I might have here from you experienced guys!
Setup: Pihole + NordVPN
Clients that keep their connection through Pihole - and Pihole IP adress that doesn't change on reboot...
Clients losing Pihole connection. My remedy is reinstallation of Pihole, which then suggests other addresses: ip 10.8.2.6/24 and gtw 10.8.2.1
Instead I enter the RPi's ip 192.168.0.194/24 (which is set as static in my router TPlink Archer C2300) and gtw 192.168.0.1 (router gateway).
When Pi-hole gets installed, it installs the software package dhcpcd5, if not installed already, for applying network related settings:
pi@noads:~ $ apt show dhcpcd5
Description: DHCPv4, IPv6RA and DHCPv6 client with IPv4LL support
dhcpcd is a one stop network management daemon which includes
* RFC compliant DHCPv4 and DHCPv6 clients
* DHCPv6 Prefix Delegation support
* IPv4LL (aka ZeroConf) support
* ARP address conflict resolution
* Link carrier detection
* Wireless SSID profiles
* ARP ping profiles
pi@noads:~ $ sudo service dhcpcd status
Active: active (running) since Sun 2020-01-19 23:30:48 CET; 1 weeks 5 days ago
The installer also configures a static IP address instead of obtaining a dynamic one from your router DHCP service (circumventing your DHCP lease reservation on your router):
If want Pi-hole to be on another address, you can edit above file, reboot Pi-hole and run below one and selecting reconfigure to let Pi-hole know of the address change:
