I have a similar issue and I have set my dns server on the rooter to the pihole at 223 however my server IP is still 1. I have similar log to the one posted here . Is there a way to resolve this or set the Pihole to handle DHCP ?
I moved your post to a new topic.
Tools > Generate Debug Log
Hello everyone ,
I am quite new to these forums , I have been trying to resolve my problem for the past 5 days, and after multiple installations and searching through forums online I finally gave up and decided to ask for help .
I have this installation on a raspberry pi 3 , I have my Linksys smart wifi router pointing at pihole as its dns server, all the requests seems to be going through pihole but its not actually working to block these ads on network devices, Pihole is only working on the raspberry pi its installed on .
Its also been giving me rate limit errors which I resolved by changing a confi file, and setting the rate limit to 0/0, Also some errors to do with packet sizes.
To block ads , network wide. Set as the dns server on the dhcp settings of my Linksys smart wifi router.
It is only blocking ads on the raspberry pi device but none other.
tricorder.pi-hole.net/D4G5iThH
Your debug log shows no errors, and is working fine.
[2022-01-02 22:50:16.071 16268M] Imported 114944 queries from the long-term database
[2022-01-02 22:50:16.072 16268M] -> Total DNS queries: 114944
[2022-01-02 22:50:16.073 16268M] -> Cached DNS queries: 3727
[2022-01-02 22:50:16.073 16268M] -> Forwarded DNS queries: 106040
[2022-01-02 22:50:16.073 16268M] -> Blocked DNS queries: 4190
[2022-01-02 22:50:16.073 16268M] -> Unknown DNS queries: 0
[2022-01-02 22:50:16.073 16268M] -> Unique domains: 1624
[2022-01-02 22:50:16.073 16268M] -> Unique clients: 3
[2022-01-02 22:50:16.073 16268M] -> Known forward destinations: 11
However, you distribute your router's IP as DNS server via DHCP. You could exchange this IP for Pi-hole's IP to announce it as DNS server via DHCP. This would have the advantage that you can see individual clients on your dashboard and can use the group management feature.
[✓] IPv4 address(es) bound to the wlan0 interface:
192.168.1.223/24
Timeout: 10 seconds
* Received 332 bytes from wlan0:192.168.1.1
Offered IP address: 192.168.1.223
Server IP address: 192.168.1.1
Relay-agent IP address: N/A
BOOTP server: ecosystem.home.cisco.com
BOOTP file: (empty)
DHCP options:
Message type: DHCPOFFER (2)
lease-time: 86400 ( 1d )
renewal-time: 43200 ( 12h )
rebinding-time: 75600 ( 21h )
netmask: 255.255.255.0
broadcast: 192.168.1.255
domain-name: "cust.communityfibre.co.uk"
hostname: "raspberrypi"
dns-server: 192.168.1.1
router: 192.168.1.1
--- end of options ---
Additionally, you use IPv6. That's OK, however your clients got GUA addresses (2a02:....) which might change frequently due to changed prefixes. You should see if you could use stable ULA addresses instead:
A post was merged into an existing topic: Pihole Setup Complete, Not Blocking Ads?
Thank you for the reply, After looking at your reply, I realised that I could add more lists to gravity and help me block more ads and other malicious traffic that I was after. Very useful insight, I have been trying to advertise Pihole's address as the DNS through DHCP to use the group management but for some reason It has not been successful.
I will look further Into the IPV6 issue and try resolve that, Thank you !
