Clients Chart Not Loading (Spinning Wheel)
Pihole admin dashboard display clients chart correctly
Pihole admin dashboard does not display clients chart correctly. It also appears that domains blocked is off (maybe doubled).
I am on the FTLDNS branch for core and web.
-rw-r--r-- 1 www-data www-data 131713388 Mar 28 19:11 /var/log/lighttpd/error.log
   2018-03-26 06:25:05: (server.c.1534) logfiles cycled UID = 0 PID = 7266
   2018-03-26 16:18:10: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Fatal error:  Uncaught ArgumentCountError: Too few arguments to function resolveHostname(), 1 passed in /var/www/html/admin/api_FTL.php on line 308 and exactly 2 expected in /var/www/html/admin/scripts/pi-hole/php/FTL.php:143
   2018-03-26 16:18:10: (mod_fastcgi.c.2543) FastCGI-stderr: Stack trace:
   2018-03-26 16:18:10: (mod_fastcgi.c.2543) FastCGI-stderr:   thrown in /var/www/html/admin/scripts/pi-hole/php/FTL.php on line 143
   2018-03-26 16:19:11: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Fatal error:  Uncaught ArgumentCountError: Too few arguments to function resolveHostname(), 1 passed in /var/www/html/admin/api_FTL.php on line 308 and exactly 2 expected in /var/www/html/admin/scripts/pi-hole/php/FTL.php:143
   2018-03-26 16:19:11: (mod_fastcgi.c.2543) FastCGI-stderr: Stack trace:
   2018-03-26 16:19:11: (mod_fastcgi.c.2543) FastCGI-stderr:   thrown in /var/www/html/admin/scripts/pi-hole/php/FTL.php on line 143
   2018-03-26 16:20:12: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Fatal error:  Uncaught ArgumentCountError: Too few arguments to function resolveHostname(), 1 passed in /var/www/html/admin/api_FTL.php on line 308 and exactly 2 expected in /var/www/html/admin/scripts/pi-hole/php/FTL.php:143
   2018-03-26 16:20:12: (mod_fastcgi.c.2543) FastCGI-stderr: Stack trace:
   2018-03-26 16:20:12: (mod_fastcgi.c.2543) FastCGI-stderr:   thrown in /var/www/html/admin/scripts/pi-hole/php/FTL.php on line 143
   2018-03-26 16:21:29: (mod_fastcgi.c.2543) FastCGI-stderr: PHP Fatal error:  Uncaught ArgumentCountError: Too few arguments to function resolveHostname(), 1 passed in /var/www/html/admin/api_FTL.php on line 308 and exactly 2 expected in /var/www/html/admin/scripts/pi-hole/php/FTL.php:143
   2018-03-26 16:21:29: (mod_fastcgi.c.2543) FastCGI-stderr: Stack trace:
   2018-03-26 16:21:29: (mod_fastcgi.c.2543) FastCGI-stderr:   thrown in /var/www/html/admin/scripts/pi-hole/php/FTL.php on line 143
Please let me know if you need anything else to debug.
Thank you,
David
The full debug log would be best
Here you go: n3psfn6x88
I have somewhere of an odd setup as I am forwarding request to the "stubby" daemon which uses dns over tls. I wouldn't think that would really affect the pihole web interface though.
Hi Jacob,
Edited
I have tried different browsers WITHOUT success. I have also tried some other solutions in other threads (like completely removing the WWW dir and doing a fresh git.
I'm definitely not a php guy, but looking in the stack trace and at the file mentioned (api_FTL.php), it does appear the wrong amount of parameters are being passed. I'm assuming that is why I'm getting a 500 error when the admin site calls to get the client info
Let me know what you think.
Thank you,
David
Had the same errors. Found the fix.
change line 308 from
$forward_dest[resolveHostname($tmp[2])] = floatval($tmp[1]);
to
$forward_dest[resolveHostname($tmp[2],true)] = floatval($tmp[1]);
Chart works great now!!
It works if you use true or false…just seems to need a second parameter.
Maybe one of the dev's will see this and add the fix into the branch they are working on.
Pinging @DL6ER or @Mcat12 for their opinions.
PRs are also welcome if you want to contribute your fix. It would help the fix get in place faster.
As @zeit0dn1 mentioned, the proposed change does fix the issue.
(I opened a separate issue regarding the doubling of domains blocked.)
It did work here: Cant see my graphs - #4 by nero355
Sorry, I apparently missed that, discourse emails are somehow still now very reliable for me (I anyhow get pinged way too often :smile: ). I'm in the train without a laptop near me, but I try to remember to look at this. Feel free to ping me again if I forget again...
It is now fixed
https://github.com/pi-hole/AdminLTE/commit/71a7c84cba874b6c931506302dd16db4fee1c679
Solid. There's a few other threads I will post this in.
