Certain pages won't load in Safari
All non-blocked domains (websites) should load in all browsers.
Some sites are not loading in Safari (10.1), both on macOS (10.12.) and iOS(10).
These are in particular German news sites (www.spiegel.de, www.zeit.de), but also for example repubblica.it.
The browser's network tab reveals that safari does not abort resolving certain blocked domains. In case of the German news site I could identify script.ioam.de.
Any ideas on how to get these pages to load in Safari with pi hole enabled?
n09u6ayny2
Running the stock lists, I do not have any issues with either of these sites. The only domain being blocked I see in your debug log (and in my own stock lists) is script.ioam.de, but I am able to load the sites even with this domain blocked.
Will you try this:
Also, you may be running into this issue:
Thanks for the quick reply.
Here's an exert from the pihole logs when accessing one of the sites with Safari:
Jul 10 21:03:22 dnsmasq[576]: query[A] script.ioam.de from 192.168.178.1
Jul 10 21:03:22 dnsmasq[576]: /etc/pihole/gravity.list script.ioam.de is 192.168.178.24
Jul 10 21:03:23 dnsmasq[576]: query[A] script.ioam.de from 192.168.178.1
Jul 10 21:03:23 dnsmasq[576]: /etc/pihole/gravity.list script.ioam.de is 192.168.178.24
Jul 10 21:03:25 dnsmasq[576]: query[A] script.ioam.de from 192.168.178.1
Jul 10 21:03:25 dnsmasq[576]: /etc/pihole/gravity.list script.ioam.de is 192.168.178.24
Jul 10 21:03:29 dnsmasq[576]: query[A] script.ioam.de from 192.168.178.1
Jul 10 21:03:29 dnsmasq[576]: /etc/pihole/gravity.list script.ioam.de is 192.168.178.24
Jul 10 21:03:37 dnsmasq[576]: query[A] script.ioam.de from 192.168.178.1
Jul 10 21:03:37 dnsmasq[576]: /etc/pihole/gravity.list script.ioam.de is 192.168.178.24
Jul 10 21:03:53 dnsmasq[576]: query[A] script.ioam.de from 192.168.178.1
Jul 10 21:03:53 dnsmasq[576]: /etc/pihole/gravity.list script.ioam.de is 192.168.178.24
Just an endless list of this.
Some of the other tips and tricks are not really applicable, as they suggest the one or other Chrome extension. I, however, am only experiencing the described difficulties in Safari.
I'm wondering: can this be a router related thing? I'm using a FritzBox 3490.
There are several FritzBox issues throughout this forum--more than any other router, so I wouldn't dismiss it as a possibility.
You could still try the whitelist extension just to see what loads.
I would also make sure your cache(s) are flushed just to rule that out.
I tried it with a different setup, a different router. This time I'm on a raspberry pi as a router, and it is also running pi hole.
Sure enough there are no problems at all in Safari. With an empty cache I get this pair of lines exactly once while loading www.spiegel.de:
Jul 11 07:10:07 dnsmasq[4374]: query[A] script.ioam.de from 192.168.0.74
Jul 11 07:10:07 dnsmasq[4374]: /etc/pihole/gravity.list script.ioam.de is 192.168.2.34
So indeed a FritzBox problem after all? Any ideas on how to tackle those?
I recall seeing solutions where an updated firmware solved some issues; I think it was due to DNS Rebind, but it might be worth checking out if a newer firmware exists and see what's in the release notes for it.
For the record: The firmware on my FritzBox is up to date. Will investigate other possible solutions.
OK. Please let us know what you find out. Some of the other posts may have had a different model, too, so that could make a difference.
@creimers Do you have an update on this for us?
Good evening. I don't have an update for now. Have not tried anything else yet. I can report, however, that I have a FritzBox 3490. I'm thinking of returning it to the shop where I bought it and just get another router.
