I did an upgrade of my DietPi system to Bullseye and now I can't access DietPi WebUI. I get a 503 Service Unavailable message.
I see no obvious errors,any suggestions?
Thanks
Paul
Thanks
Paul
I did a pihole -r and chose repair,all good except this error:
[i] Target: https://dbl.oisd.nl
[✗] Status: https://dbl.oisd.nl (410)
[✗] List download failed: no cached list available
Did you install Pi-hole via dietpi-software or with the official installer?
dietpi-software list | grep pi-hole
The URL(s) for the list you use seems to have changed indeed: oisd | Set up
As of the 1st Jan that list is no longer maintained.
It was installed with dietpi-software, but before I upgraded to Bullseye.
If I to uninstall and reinstall, will it keep my settings?
Ah ok,thanks
Okay, then at best reinstall it via dietpi-software as well, to assure PHP and all required modules are installed and configured as expected. This should have been part of our distro upgrade guide: DietPi - How to upgrade to "Bullseye" - DietPi blog
If you uninstall it, all data and configs will be removed. Hence reinstall it (as part of the guide):
dietpi-software reinstall 93
